Question about Coleman Heating & Cooling
Evcon eb15b not getting any heat and fan isn't blowing in Coleman electric furnace...
    Genius:
  • Coleman Master
  • 1,363 Answers
Thermostat, heat sequencer or contactor, no 240 volt power no 34 volt power
Posted on Aug 20, 2015
ngafm
  • 166 Answers
SOURCE: coleman mobile home electric furnace
Peace,
It seems you need hands on servicethis time !
ngafm
Bless You,
Please leave me a rating before you sign off!
Thank You
Posted on Sep 07, 2008
SOURCE: We have a coleman evcon
It sounds as if your furnace is exceeding the limit tempperature of the manual reset switch. The coleman is designed for the fan to continually run when this limit switch is tripped in order to keep the heat exchanger cool.( it is a safety feature) afew things may be happening.
1. the manual limit switch( the one you have to push) may be defective.
2. The fan may be running at too low of a speed. Turn power off at circuit breaker. locate circuit board on the board there will be one terminal that says heat if the red wire from the blower is on it tthen you may need to up the speed. follow the wires from the blower to the board if it has multiple speeds then you can isolate the red and put the blue or orange on the heat terminal.
3. the board may have an adjustable fan on and fan off pin selector if it is set up to come on to long or go off to soon it may not be controlling the temp of the heat exchanger properly.
4. I would also suggest checking to see if the orifices and gas valve are set up for your sytem correctly.
these are just simple ideas let me know how things go.
Posted on Oct 15, 2008
morefords
SOURCE: have a coleman evcon furnace
Your centrifical swith is stuck open on your blend motor. I found that removing the blend motor housing and spinning the stuck motor (from setting over the summer) will get you out of a bind ,.but you may end up needing this centrifical switch (locatedon the bottom of the blend/fresh air intake) motor replaced.
Posted on Nov 07, 2008
SOURCE: I have a Coleman/Evcon Presidential
I would like to adjust flame for more heat. can you tell me the color of flame?
Posted on Dec 15, 2008
  • 146 Answers
SOURCE: My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
Posted on May 28, 2010
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Coleman/ Evcon central electric furnace Eb15b thermostat on auto will not blow air out i hear a click u see and feel it heating up then i hear Another click dont see nor feel heat then but put thermostat...
check the thermostat setting on back for electric heat. sounds like it is on gas heat. the fan should turn on right away if it is electric or heat pump.
Nov 15, 2014 | Heating & Cooling
Coleman Evcon Eb15b we replaced thermostat last night so that wasn't it when. Put in auto for heat u can hear a click. See where and feel it heating up tgen u hear. Another. Click and nothing even the heat...
if you turn on heat and no fan comes on, the electric will over heat and trigger high limit switch. the switch either self resets after it cools for a while or needs manual reset. read directions on thermostat for electric heat. energizes fan at same time as heat on calling from stat.
Electric furnace fan works heater does not
coil could be broken. open the cover hold the door switch and look to see if the coil glows when the heater is turned on if not turn off the power then remove the coil then turn on the power and check the voltage you should get 210V A/C on a meeter if you do or yo can do this firs, check for continuity on the coil if you get continuity then check for voltage. if no voltage check the breakers or check the breakers first the electric heater needs two breaker if one is tripped you could have a blower and no heat.
Oct 08, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
No fan when ac kicks on Ihave a eb15b funace with a coleman ac
The heat will normally use a low speed on the fan, & the AC along with the fan switch on the thermostat will use the high speed. The thermostat turns that high speed on when there is a call for cooling & is the same switch if you were to manually turn the fan from auto to on. Try turning the fan on @ the thermostat. If it works, then replace your thermostat. If it doesn't, it could be a bad fan speed, a bad fan relay on a control board or external relay, or a loose or broken green thermostat wire.
Apr 14, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
Furnace kicks on then shuts off
Coleman furnaces us a temperature delay with a temperature on around 130F to 150F and off around 110F.
If the inrush of cold air cools the delay below the off temperature the fan will go off until the heater heats it up to the on temperature.
Jan 06, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Heating & Cooling Logo
100 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
