Question about Ruud UAKA037 Air Conditioner
What is the unit specs - Ruud UAKA037 Air Conditioner
Can I use stove oil (diesel) in my 70,000 BTU Reddy Heater?
the fuel to use will be on the specs plate attached to the unit as different fuels have different calorific values using different fuels for which the unit has been designed to use will cause smoke and other operational problems
if there is no specs plate attached , contact the manufacturer and get the details from their engineers
Nov 09, 2017 | Reddy Heating & Cooling
Specs on Z4 2L 2006 CL
endless , answers possible.
google that.
say what is the focus.?
or concern
or?
Jun 26, 2014 | 2006 BMW Z4 Roadster
Can I upgrade e 4100 processor?
Based on the motherboard specifications, and looking at the specs that the Gateway lists for the unit, A Pentium 4 processor socket 478 at 2.8 GHz is the maximum for that machine. Gateway specs show exactly that is what is installed on the E4100. Unfortunately, most pre-built machines have little or no CPU upgradeability since they are built to specs.
Dec 03, 2013 | Gateway Computers & Internet
Camper 12 volt system will not recharge.12 volt lights make low voltage alarm sound
most likely cause other than faulty wiring or bad ground is a faulty inverter. the specs should be taped to a panel near the unit or folded up nearby depending on the tech that installed the unit. use a voltmeter to confirm proper operating thresholds (if no spec sheet is present you can get one but contacting the manufactuer and providing a model number)
Oct 15, 2013 | Cars & Trucks
I need an inverter for my 1 hp air condition. how many watts do i need especially at start-up? modified or pure sine wave. Thank you.
The most important spec that you will need is the LRA rating. What this stands for is locked rotor amps. The LRA rating is what the AC unit will draw from the inverter while the compressor starts up. This is a very important spec when sizing an inverter for use with an AC unit. After you get this spec you will multiply it by the voltage and this will be the startup wattage needed by the inverter.
For example if your LRA is 60.6 amps if you multiply this by 115 you will get roughly 7000 watts at start-up.
The next thing to take into consideration for a AC unit is battery bank size. Your next step in setting up a system for use with an AC unit is finding a sufficient recharge source for the batteries. You will want to have a minimum of a 150 amp alternator to recharge a system with a small AC. I do not know whether you will be able o accommodate them.
Why don't you go for solar power as standby OR a small generator????????
Aug 05, 2011 | Inverter Heating & Cooling
Dear sir/madam, Please send me the link of downloading laptop usb driver laptop-hp pavilion dv6 (hp pavilion entertainment pc) operating system-windows vista drvier- usb ports mail id : urban...
Getting exact drivers for the part of your PC you need could be a bit tricky as the DV6 comes with numerous specs. Could be 32bit or 64 bit all these will have to be put into consideration when you want to download drivers for your unit. to get the precise driver you need visit the HP customer support website from there you can identify your unit specs and download the right driver for your unit.
Hope this solution has been helpful?
Apr 13, 2011 | Computers & Internet
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
USA SPEC PA11-Vol unit will not play iPod using the iPod cable.
where did you plug this behind the radio ? or at the cd changer cable ?, the interface needs to be plug into the radio not the cd changer cable
Dec 20, 2009 | USA Spec (PA11-VOL) for iPod
I have a 1996 dodge ram 2500, 5.2L, the oil light comes on and the oil gauge fluxuates, but there is plenty of oil in it. There in no apparent issues with the oil pump (no grinding/squeeling) I am...
Just to add, hope this helps with sensor location. The spec I saw was 30--80 psi oil pressure at 3000 rpms. In the old days they used to say for generic spec, 10 psi for every 1000 rpms. Always use the proper spec. You might be able to use analog pressure gage to screw in to replace sending unit to double check oil pressure. Just my opinion.
Nov 26, 2017 | 1996 Dodge Ram 2500 Club Cab
Ruud UAKA037 Air Conditioner Logo
20 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
