I have an eco bubble 7.5kg washer - the rubber ring that seals the front door has a bit missing from it, so the machine isnt water-tight and leaks all over the floor.
My question is: (1) is there some type of repair kit to patch the seal so it doesn't leak, and (2) how easy is it to remove and replace the grey rubber ring?
textonor
  • 130 Answers
SOURCE: metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Posted on Jan 23, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE2 Washing Machine Leaking
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
Posted on May 04, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Posted on Feb 16, 2009
  • 1294 Answers
SOURCE: whirlpool duet water leak
Open your wall faucet to full pressure to stop the drip. If this does not work simply change the inlet valve of the machine which is at the top, where the water enters the machine. You can do it yourself. And rate me plz if helped.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Mar 31, 2009
  • 157 Answers
SOURCE: BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Posted on Jun 30, 2009
Model wm0642hw front load. it leaks by door frame.rubber seal with clamp.only 2 years old. do i need to change the door frame outer part a151? thanks for your response in advance
Hi, If the door isnt loose or broken? Its more likely to be the rubber door seal if its leaking between the seal and the door glass. Check the edge of the seal where it touches against the glass for damage or ware if its ok clean any soap residue or bits from the glass.If it still leaks change the door seal.
Regards Elect App
Jul 13, 2011 | LG WM-2277HW Front Load Washer
I have water leak out of our front loader, it leaks out rite in the middle from the bottom of the door. I am not sure if it is from the small hole in the door or if it because of a bad seal. The rubber...
the wire ring just keeps the seal in place,, make sure the bottom of the door glass is clean,, if so look at the seal and see if it is pushed in alittle around the bottom,,you can take a hair dryer and heat it up while pulling it back out ,, ( just the lip part) if that doesnt work you will need to replace the whole gasket
Jan 24, 2011 | LG WM-2277HW Front Load Washer
Washer leaks during spin cycle. my daughter pulled the drum out of alignment temporarily while pulling a comforter out of the washer. the door seal is intact although there is a wire ring that came out...
The spring goes around the door seal it needs to be stretched around the small lip that holds the seal in place. The spring is where you grab it with needle nose pliers. the spring goes on the bottom. You will see where the rubber seal has a wider spot this is where the spring should be right at the 6 o'clock position. This is a little tricky to do the first time trying but keep at it you will get it.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After my washer spends the rubber comes
Do you mean the door seal has come loose.
Disconnect the machine from the power. Open top hatch by removing two screws in the back and sliding top lid back and up to remove.
Check down from the top of the machine and feel around the door seal. Make sure there are no holes or tears in the seal. Try and refit seal. there is a metal ring around the drum and also around the front panel where the door seal joins. Make sure the are tight and fit in properly.
Let me know if I didnt understand the problem.
Good luck.
Ash
Oct 22, 2009 | Samsung WF448AAP Front Load Washer
Front load washer leak
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
The door leaks on my whirlpool front load model wfw8300sw03, looks like the door isnt sealing tightly, if I push on the door it stops lealing, any ideas?
you might have a bent door hinge, but most likely you have a worn door boot. its the grey rubber thing that the glass seals to.
try to lift up on the door to get the hinges back into place and if that doesnt work then you might need to replace the door boot.
look at the edge of the boot where the glass hits it. the glass must seal to the rubber and if the rubber is worn or torn then it wont seal.
not an easy piece to replace but it can be done. i wouldnt recommend trying it first as you will find it very tight to get your hands into and the clamps are hard to figure out as well.
Feb 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking door due to the wire ring that holds rubber seal
Bosch Nexxt 500 WFMC3301 Front Load Washer how
to get the metal ring back on.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the metal rings.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 06, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Leaking door
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Jul 25, 2008 | LG WM-2277HW Front Load Washer
Water leaking from front door
not really due to therebeing 3 holes at the bottom of the door seal which lets water out that is stuck in the seal
Sep 12, 2007 | Miele W969 Washer
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
