Question about Ruud UAKA037 Air Conditioner
WHERE IS THE LIMIT SWITCH - Ruud UAKA037 Air Conditioner
  • 148 Answers
It in the furnace
Posted on Nov 24, 2013
Furnace blowing cold air after replacing limit switch
Limit switches are safeties and require a manual reset. They are also a Normally Closed contact. A hi temp. thermostat operates on its own. If you are sure it is a limit, find the red little button and listen for it to click. Sometimes they push pretty hard.
Feb 03, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Honeywell s9200
YOU MUST HAVE THE 2 TERMINAL GOING TO THIS LIMIT MIXED UP AND SHORTING OUT. CAN YOU TELL ME WHAT IT IS INSTALLED IN OR DO YOU HAVE THE WIRING DIAGRAM TO REFERENCE?
Oct 20, 2012 | Honeywell S9200U1000 - Hot Surface Control...
Honeywell S9200 causes transformer death when limit switch attached
If jumping 1 to 7 is blowing the fuse it sounds like a bad board.Not familiar with those but as you said, normally closed limit would be the same as a jumper. Check your dip switches first but I'm thinking bad board/direct short.
May 24, 2017 | Honeywell Heating & Cooling
My friend has a bad Genie garage door opener down limit switch (Door goes down and right back up again). Limit switch is made by Tane with part No.'s on it: FM-102BR-138 and 33969B. Would Limit Switch...
This is the close limit sensor so yes it should work. They have them for $2.40 right now from an Amazon vendor - http://www.amazon.com/Genie-Excelerator-Close-Switch-33950S/dp/B00283OBXY/ref=?ie=UTF8&m=A1CTO3U79X1RZ3
You can also buy replacement sensors as a 10 pack in case you end up needing more from here -
http://dpcdist.com/flangemountcontactandmagnetendleads.aspx
Sep 16, 2011 | Genie Company Genie Excelerator Down Limit...
I AM REPLACING THE HEADER IN H250FDN HEATER. NEW HEADER INSTRUCTIONS MATCH OLD HEADER AND NUMBERS MATCH ON OLD AND NEW BUT NEW HEADER IS DIFFERENT. OLD HEADER HAS 2 LIMIT ON BOTTOM NEW ONE HAS 1 ON BOTTOM...
As long as it still has 2 hi limit switches, this will be easy.
You will need one wire going from one limit switch to the other. (on any terminal)
take either of the incoming wires from the old limit wiring and connect to second terminal on either limit switch.
Now take the last remaining wire and connect ot to the last terminal on the second limit switch.
Basically, you are just creating a bridge. Power will go into first limit switch, then go into the second limit switch via the first wire indicated above. Then the power will go back out to the pc board. If a high limit switch trips, then power is cut off (cicuit opens) and it tells the cpu there is a problem and shuts down the heater.
So to simplify: connect the wire in between the two limit switches. Then put the other 2 wires anywhere.
May 04, 2011 | Hayward 250fdn Low Nox Nat Gas Swimming...
Last week my furnace went out. My landlord called a furnace technican and he said that the limit switch was fried. So he replaced the limit switch and did a tune up of the furnace. It took 2 days for the...
Hello, a limit switch will open when the furnace overheats due to restricted airflow, check the blower wheel make sure it is clean and also make sure the blower motor is running at good speed and not dragging. Sometimes a weak capacitor can slow down a blower motor to the point that the limit switch will open. Not sure what kinda tune up the tech did but you dont replace a limit switch untill the cause of the limit switch opening is found.
Mar 01, 2011 | Heating & Cooling
Chamberlin garage door opens to top limit bounces back to return down about 6 inches and then returns to open limit. What adjustments are neccessary?
The limit switch of both the sides are not reached. The drive must be realigned to work till the door closes fully so as to touch the limit swittch to switch off.
Similarily the open door must go to the extreme point to cut off with the activation of the limit switch.
Sep 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Limit switch open furnace wont heat
If the limit switch is open try to jump the wires out... this should turn the heat back on. and if it does replace limit... if it dont let me know and we'll try again
Apr 06, 2010 | Ruud UAMB Air Conditioner
Craftsman opener, limit switch not stopping motor.
try adjusting limit switch wheel to shut off just a little earlier by spinning wheel closer to limit if this doesnt help im afraid sometimes even new parts can be faulty you might try another replacement
Sep 30, 2009 | Electrical Supplies
Ruud UAKA037 Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
