Question about Kenmore 21.8 cu. ft. Side-by-Side Refrigerator with Fresh-n-Ready Bin
How does the fresh and ready bin for the fridge go back together?
2 Suggested Answers
SOURCE: What is the fresh and ready bin used for?
The fresh and ready bin is used for fruit. You can place various fruits in the tilt out bin and grapes in the berry basket. The berry basket is made do it can be lifted out of the assembly and run under the faucet to rinse your grapes (it has holes in the bottom). The entire fresh and ready assembly is manufactured by a Whirlpool supplier in Southern Indiana.
Posted on Oct 10, 2009
Ice maker makes ice but will dispense through door. Checked and it is not clogged.
Good day!!!
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues. If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
I hope this information will be helpful...Thanks for using fixya...
Sep 09, 2011 | Hotpoint HSM25GFRSA
Samsung RS253BASB SidebySide Fridge Not being Cooled
Probably bad fridge tstat sensing bulb (tstat)
possibly bad open heater in area of fresh vegetable bin
or damper assy not set correctly
Dec 08, 2007 | Samsung RS2534 Side by Side Refrigerator
GSS25KGPJWW side by side; refrigerator running almost constantly and my wife noticed that food in the "Fresh Produce" bin and the "Deli Fresh" bin was freezing. I now have the...
Try shutting the vent between the freezer and the produce bins, the freezer should be colder-down at least to 5 degrees, turn the freezer control to max cold and leave the fridge temp where you put it. the go from there
Jun 24, 2011 | GE Refrigerators
I have a Kenmore Trio 76504 that the refrigerator keeps freezing products on the back of any shelf or crisper bin
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Good luck in solving the problem....
May 15, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Sep 29, 2009 | Kenmore 21.8 cu. ft. Side-by-Side...
Ice doesn't come out into glass. Makes some ice but is larger pieces stuck together or flat pieces in bottom of container. Green light in back of container is on. I set the freezer to colder temp but...
You are not using enough ice.
You may need to dump the bin every week or so and keep fresh ice in the bin.
When you go through several defrost cycles the ice tends to eventually melt and stick together.
Mar 10, 2009 | Refrigerators
Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
