Question about Garmin StreetPilot C320 (010-00401-00) GPS Receiver
Garmin c320 does any one know wether the Garmin c320 can be run on 24 volt as well as 12 volt???
  • johnchrisp Oct 10, 2007
    yes according to Garmin it will operate on 24 volts
  • boris1969 Apr 26, 2009
    i need the support for a car for gps c 320
    Novelist:
  • 113 Answers
Yes
320 specs
Posted on Oct 26, 2007
SOURCE:
Can i use garmin C320 street pilot in italy
Most stock units are equipped with a US & Canada map if purchased in the US. Yes, the unit will work in Italy but you will need to add a Europe Map on an SD card, as the internal memory may not be large enough to hold both maps.
Feb 17, 2014 | Garmin StreetPilot C320 GPS Receiver
Hi i have a problem with my Garmin GPSmap 76CX. It is only work when it is plug with the usb cable. it doesn't work with the battery or the 12 volts cable? Can you help me
It is not the battery,the problem is with the 12 volts cable.Please buy a new cable and then your Garmin will charge even with the cable.
Let me know the result
Oct 20, 2008 | Garmin GPS
Is this unit avaliable to be used on 12 volt and 24 volt vehicles
Yes as long as you use the original garmin charger that comes with it. The garmin charger steps down either 12 or 24 volts to match the 5 Volt required input voltage of the satnav.
May 05, 2011 | Garmin nuvi 250W GPS Receiver
My garmin 760 nuvi keeps freezing while using it on the road. i have updated it to the lifetime updater. What can i do? hope you can help
If you're running the latest system software on that GPS, then I would say send it back to Garmin, including all the powercords etc...
You know, they sometimes have issues with their 12 volt power adapters. You may want to contact Garmin about getting a replacement cord. That was the issue with my wife's Garmin Nuvi 200.
Aug 03, 2010 | Garmin Nuvi 1350T
Battery replacement now ca't find satellite Garmin c320
More than likely when you reinstalled the gps receiver (the board with the wires connected to it) at the top of the receiver you did not position it properly. If it is not positioned properly it will not receive a satellite signal
May 06, 2009 | Garmin StreetPilot C320 (010-00401-00) GPS...
Garmin C320
Yes, even a 2GB card will work in the Garmin Streetpilot. You will transfer your additional maps to the SD card, plug it into your unit, and then go to the Map System page to activate which map you want to see.
May 28, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
Tracking satalites
Update the firmware from Garmin website, and do master reset. That should fix the problem. worked on mine
May 23, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
My garmin c320 wont track any satalites
hi, my garmin c320 has a clear view of the sky but it cant track any satalites i don't know what to do. or if there is anything to do. can some please help me. thanks
Apr 29, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
Garmin StreetPilot C320 (010-00401-00) GPS Receiver Logo
134 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
