Question about Plumbing
Grohe Ladylux Faucet Spray Stuck on
The spray feature on on faucet is stuck on. It appears some sort if seal has disintegrated. What part do I order to fix it?
4 Suggested Answers
  • 127 Answers
SOURCE: i have a ladylux kitchen faucet and the
Call Grohe customer service...they will send you a new one for free.
Posted on Oct 18, 2009
  • 92 Answers
SOURCE: grohe ladylux cafe kitchen faucet:
check and see if the weight is on the hose going to the handle, also check to see if the hose is free to fall down and that it is not hanging up on piping down under the sink
Best of Luck
Richard
Posted on Sep 07, 2011
SOURCE: Have a Blanco single-handle pull-out faucet with
Contact Blanco and the company will send you a new sprayer handle for free.
Posted on Jan 24, 2013
Hot waterside has no presure
sometimes the is a piece of dirt gets stuck in the orfices take apart and clean
Oct 12, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
I have Grohe Ladylux and the flow will arbitrarily switch from stream to spray on its own.
Mine would stick in the spray setting. I soaked the whole head in vinegar to clean it and the problem went away.
Oct 05, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
How do I set the spring tension on a ladylux kitchen faucet with pullout spray
Personally, I didn't think it was supposed to. I assumed the spring was a form of stress relief for the hose as it nears the pass-through.
Sep 12, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Need to tighten my ladylux
Grohe has a special tool that is used for installation that comes with the faucet. You have to remove the pullout spray and remove the curved neck of the faucet by pulling out. Insert the tool in the main body and tighten from above. Most plumbers will keep this tool when installing. I don't know if Grohe still uses the same system still today, but they did in the past.
Sep 03, 2013 | Grohe Ladylux Cafe Faucet with PullOut...
How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
I have a Grohe Ladylux plus kitchen faucet very similar to this one, when I turn the water on there is a slight clunk and the water flow decreases. I am assuming I need a new valve but I havent' been able...
Before you start taking the whole faucet apart try taking the airiator or head of the end of the faucet. It may just be some sediment blocking the filter screen on the head. Unscrew the head and see if the water flows with the head off.
Jun 12, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
Jun 09, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Plumbing Logo
43 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
