Question about Cameras
Samsung camera problems
Camera seems to be frozen. put in new batteries but once turned on beeps 3x then turns off. DigimaxD53. Lens is frozen also
jackboy
  • 2985 Answers
SOURCE: I am have Samsung Digimax S600
Well all the time these item [didgi cams and small electronics of all sort do seem to have a high fail rate. But as I said less than a year - take it back
Posted on May 25, 2007
SOURCE: Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
Posted on Oct 21, 2007
  • 4 Answers
SOURCE: Lens stuck
Here is how I fixed this problem. I grasped the lens around the base (larger part) like you would if you were going take off a beer bottle cap.
Very gently while sliding my thumb and index finger around the lens, I rocked it back and forth. DO NOT TRY TO TWIST OR PUSH,.....It felt like it "popped" back on track.
My assumption was it was probably hit from the side, and could not retract, once it was rocked back on track, it worked fine. It felt like it loosened a tiny bit as well.
Good luck.
Posted on Mar 02, 2008
SOURCE: Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Posted on Mar 31, 2008
SOURCE: I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Posted on Jun 17, 2009
Camera turns on momentarily, beeps 3x, turns off with lens out
I think it could be a memory card problem. Can you try taking out the camera and put on the camera and see what happens.
Aug 06, 2009 | Samsung Digimax D53 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
Why is the camera beeping?
I had t he three beep problem and also the lens was open. I tried batteries - then i noticed the lens was slightly bent - i tried straightening and it snapped and went into place. then i tried turning it on and it was fine and when i turned it off the lens closed.
Maybe your lens is bent.
Jun 28, 2008 | Samsung Digimax S730 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S700 is frozen with lens open
I had this same problem, and all i did was pop out the SD card, and tried turning it on without it in there.  It powered up just fine.  I then replaced the SD card and all was well.  Possibly a problem with teh SD card.
Nov 30, 2007 | Samsung Digimax S700 Digital Camera
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
Oct 05, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
167 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
