Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Picture discoloration to left and right of screen.....
I have a 55" Philips rear projection HDTV that is about 2 years old. I've always had this issue, but it has gradually gotten worse and worse and now I figure I need to do something about it. Generally, I have panels of discoloration to the far left and far right of the screen (I have found this difficult to explain to people so have attached a picture). The picture quality is okay, it's just that when I'm in widescreen or HD format the bands of discoloration appear at the sides. The panels are in the same place. For example, if the picture was a direct overhead of a football field, the picture would be fine between the 10-yard lines, a dark shade of green. The areas of field between the 10's and the endzones would be a lighter shade of green. The middle of the screen is fine, it's just the 4 inches either side that are screwed-up. I called the Philips technical rep and he was useless. He actually argued with me that the screen was supposed to be that way! I'm totally lost with this one. I read something about side shadows and that seemed to relate to my issue?
    Problem Solver:
  • 20 Answers
Hi! Guy,
This sounds like the G2 may not be properly adjusted, providing too much beam current.
This will some times cause feather edging, or lighter than normal raster on some scenes. This set should be serviced by a qualified service tech.
Toprol
Posted on Nov 15, 2007
SOURCE:
Screen not bright
obvious solution... check the settings.... you've probably done so already though. http://www.tvrepairkits.com/xcart/product.php?productid=24696&cat=3844&page=1 dull repair kit link. love the old rear projection tv's when they work right but they're finicky and monstrous, best of luck with your fix.
Apr 22, 2012 | Philips 51PP9910 51" Rear Projection HDTV
I have static in the picture. Looks like a swarm of bugs moving around the screen. It is a phillips rear projection
sounds like poor tuner singnal solution mak sure u have gooddddddd connection with ant or cable make sure ur tv is on right station exe 2 3 4 this should resolved yur problem if not if you have bacis electronis skills i instruct u on repair
Jul 25, 2009 | Philips 55PW9363 55" Rear Projection...
Magnavox 51mp392h
replace the convergence ICs STK392-120 you will need both of them also check the 6.8 ohm resistors right next to the ICs as often 1 or 2 of them burn open. You should be able to notice the discoloration in the center of the resistors.
Mar 11, 2008 | Philips 60PP9202 60" Rear Projection...
Side shadows on picture
it sounds as if there are speakers to close to the tv or the built in speakers are not magnetically sheilded properly (maufacturer defect) if u have or have ever had speakers on the left and right side of your tv then the magnets in them will discolor and distort the screen. sometimes even long after the speakers have been moved away from the tv it will still look that way. you may try going to the library( or online )and looking in tv repair books on how to build a homade degauser unless your tv has that feature built into it in the menu somewhere like some computer monitors do. I had placed the front speaker of a 5.1 surround sound system on top my tv and it cuased that same problem, but i found out that by placing a small round magnet with a hole in the center on top of the tv (after removing the speaker for good) right where the discoloration was.. had to flip it one side or the other to get proper effect...it immediatly took away most of the discoloration and over time it disappeared. I hope this helps. Please email me at [email protected] as to your conclusion in case it will help others. thanks, Adam
Oct 10, 2007 | Philips 51PW9303 51" Rear Projection...
Philips 55PP9401 55 in. Rear Projection
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ 01341.......next, look for discolored resistor
near IC's.....replace with exact value......last = activate
Auto-Intellisense.....................T.
Sep 25, 2007 | Philips 55PP9401 55" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
