Question about Poulan FL1500LE 25cc 150 MPH Blower
Primer bulb bulb won't return to position.
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
How to rout fuel lines to primer bulb on poulan 14" chainsaw
Short line on primer bulb goes to the left side of the carb. The long side on the primer bulb goes to in the fuel tank as the return line.
Jul 23, 2014 | Poulan 14 in. 2.0 Peak Horsepower Electric...
What is the correct position on primer bulb for fuel lines
Short side of primer bulb to the carb and long side of the primer buld to the fuel tank as it's the return line.
May 05, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hey guys I have a stihl fs 85 r and I can't get
Hi Esh Weizman
Sounds like you have the fuel lines reversed going to and from the primer bulb.
I will put a picture up for you to see the routing of the fuel lines
Please take time to rate me
Bud
Oct 29, 2012 | Garden
I have a Craftsman Weedwacker 25cc 358.791030 that won't start. Primer bulb is not getting gas. Gas line is connected to the filter resting at the bottom of the gas tank. The line for the primer bulb...
that line should be longer, it contains the filter which is the pick up, and should rest inside the tank fully,, see if its possible to pull that line farther into the tank, its not going to start until the primer bulb fills
Jul 24, 2011 | Craftsman Convertible 25cc. Gas Line...
Hello, my Ryobi 410r tiller/cultivator needed new fuel line so I bought the fuel line, return and a new bulb primer. Unfortunately, I can't remember what hose goes where!!! Specifically, I've...
The primer pulls fuel through the carbruetor
So take your return line from the carb. and hook it to the inlet side of the primer and the other side
of the primer bulb transtions into the fuel tank.
You know when you have hooked it up right when you press the primer it fills with fuel and dumps back into the tank.
Jun 16, 2011 | Ryobi Garden
Won't start , can not get primer to work even after replacing primer bulb.
If your fuel filter is clean, and none of the fuel lines are pinched, then you probably need to replace the diaphragms, gaskets, and screen in the carb. Some carbs with the primer bulbs mounted on the carb have a check valve in the primer system. This is the least likely problem, but it is possible that the check valve is defective.
May 07, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Replaced primer bulb and all fuel lines still getting air in lines. ran pretty good for about 10 minutes now will start with choke but dies in a few seconds. Cannot rev. up. cleaned under both plates but...
The primer bulb pulls fuel from bottom of fuel tank,when bulb is full it will return fuel back into tank,the hose entering bulb runs in the tank to bottom with filter on the end,the return hose stops just as it enters the tank maybe 3/4",make sure the hoses entering tank are tight fit or they will pull air in and leak.the carb may also need rebuild/clean,there is a screen inside of carb that may be stopped up which will need to be replaced.(carb kit).
Feb 18, 2011 | Troy Bilt Tb70ss Gas Trimmer
Poulan 2150 put new fuel lines on geting gas trew line put the primer buld will not prime and somtimes gets stuck but will release win i pull it of carb
Check the condition of the primer bulb for hardness or cracking. If ok, remove the line that goes from the bulb back into the tank and try to pump fuel from the carburetor. If nothing, switch the position of the other line at the back of the primer and try to draw fuel again. If hooked correctly, the primer will pull fuel through the carburetor body filling all cavities and into the primer bulb. If still nothing, try switching the lines at the carburetor (it should not pump backwards through the check valves in the pumper chamber). If still nothing, switch the primer connection again. Some combination of line connections should allow fuel to be pumped through. When correct, reconnect the loose primer line to allow fuel to return to the tank. This is a good reason for replacing only one line at a time. Hope this helps!
Apr 24, 2010 | Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Poulan FL1500LE 25cc 150 MPH Blower Logo
15 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
