Question about Tablets & eReaders
Emerson 10.1" tablet will not turn on
Model em1000B tablet has a push in button to power on and starts after five seconds. Tried to turn on this morning after charging for about six hours and will not turn on. Red light shows on when charging.
SOURCE: Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
Posted on Dec 09, 2008
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
SOURCE: After i put in the
back up arnova and reflash the firmware. that solved it for me. still the wireless is fickle. sometimes, I tell it to forget network and then refind it. and sometimes it doesn't and I have to manually add it. My hunch is this model may have wireless issues.
Posted on Aug 06, 2011
SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
Posted on Sep 17, 2011
KingDWS
  • 1606 Answers
SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Posted on Mar 23, 2012
How to restart my tablet without turning it on because I forgot my password?
Look in your tablet instruction book for a procedure called 'hard reset' or a location for a small hole on the edge or back of the tablet where you can push in something non-conductive, like a toothpick to press a hidden reset switch. Without having a make and model for your tablet, it is hard to determine what exactly to do because each make and model is different. You talk about pressing the power and low volume buttons- are you holding them both in simultaneously for 10 seconds? This might be the reset procedure for your tablet, but that is not clear. One last thing to try is to hold in the power button for 10 seconds and see if you get a power off screen. If you get this, try powering off the tablet and then restarting. Also make sure the keyboard isn't on caps lock when you type your password.
Jan 03, 2015 | Tagital Taital TM 7" Android 4.0 4B MID...
Why won;t my irulu 10.1.1 tablet turn on. i push the button and nothing happens, when charger is plugged in it gets warm both tablet and plug
It sounds like you've done most of the things you would reasonably be expected to do to make it function; since it is only 2 months old I would strongly urge you to go back to the retailer and make them replace it or refund you, as your rights in most countries/states allow.
If you're set against doing this, try holding down the power and volume down key for at least ten seconds to see if this boots it into hard reset mode. If this doesn't do anything, try again holding down power with each of the other buttons to see if you can activate any other developer/reset modes.
However, I have read reports that this particular tablet has up to a 40% failure rate in its first six months.
If you can possibly get it refunded, do that and buy something else.
Jan 02, 2015 | Irulu 10.1 inch Android 4.0 Touchscreen...
My tablet want come on what's wrong with it
I've had the same problem with my RCA 10 inch tablet. I have charged it, tried the hard reset, used different chargers and even different outlets, and held the power button on for 60+ seconds with NO RESULTS! My recommendation is to contact RCA, which is what I am doing, and request an immediate replacement if yours is still under the 1 year manufacturers warranty. If you look these tablets up, you will see (as I have found) that this is apparently a common problem with the tablets. Wish I had known that prior to purchasing!
Jan 01, 2015 | Tablets & eReaders
My kocaso tab wont turn on whille charging
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Dec 28, 2014 | Kocaso Sx9700
How do I reset my Emerson EM1000B tablet? It does not have a volume button on the exterier.
There is are two small holes next to your "home" button the first one is the reset the second is the microphone. Straighten a paperclip and poke it in the hole closest to the "home" button gently until you see the tablet is resetting. This will be a "hard" reset.
Oct 24, 2014 | Tablets & eReaders
Why want my tablet come on?
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on. Support Troubleshooting Guide
Aug 07, 2014 | Kocaso M1060W Tablet
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
May 03, 2014 | Tablets & eReaders
My tablet is totally frozen!! please help
Gee if only you told us what make and model!!
Mar 26, 2014 | Tablets & eReaders
Wont start up
Mar 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Tablets & eReaders Logo
145 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
