Question about Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
Rigid 12 gallon Model wd12701 - Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
How do I remove the filter from a Rigid 4 gal portable wet/dry vac
James the attached link/video shows filter just pulls off. I also put a link to the manual and it show the filter held on with large plastic nut, which would have to be removed first.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
4 Gallon Portable Wet Dry Vac
http://www.ridgidparts.com/pdf/WD40500.pdf
Rigid WD4070 Wet Dry Shopvac Unboxing and Overview
RIDGID Shop Vac Review must have tool 2
Apr 30, 2016 | Filter Vacuums
MY5.0 12 GALLON DOESN'T RUN??
Check:
Power cord may have a broken wire.
I had to replace the on/off switch which I bought a replacement from Rigid directly; I think less than $10. Check your manual which has a parts list.
Oct 13, 2014 | Ridgid 40103 WD1270 12 Gallon Vacuum
How do you open the cover for a 4 gallon rigid shopvac
this link below will give you all the infomation you need with videos hope this helps you .enjoy..
http://www.ehow.co.uk/videos-on_4811_care-portable-shop-vac.html
Nov 03, 2012 | Vacuums
How do you remove the filter from Rigid wet dry vac?
Unscrew the 'tab/nut' at the BOTTOM of the filter and pull off the filter cartridge
Jul 07, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Motor
Replace the motor... if you live in canada, go to canadian tire or part source they'll have what oyu need to fix it.
Jun 24, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
263 people viewed this question
Top Ridgid Vacuums Experts
Dan
Level 1 Expert
ken skalski
Thomas Perkins
Thomas Perkins
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
