Question about Frigidaire FMV156D Microwave Oven
Light over the stove is to dim
I just want to know if they make brighter bulbs
  • Official Brand Answer
  • 4,342 Answers
Good Morning Paul, thank you for allowing me to assist you!
For the above-listed Frigidaire model number, FMV156D, it is not recommended to use a bulb larger than 30 watts. Your microwave does not have an option available to adjust the lights. If the light is dimmed, than more than likely your microwave is experiencing an issue with the control board, a potential wiring failure, or faulty light socket. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Posted on Nov 27, 2013
How do I fix stove top lights?
Find the manual online by going to Google and put in the make and model of your stove. It's usually found on the inside of the door. In the manual it will tell you how to replace the lights (bulbs).
Oct 12, 2014 | Whirlpool MH6130XEB/Q Microwave Oven
Adjust display brightness on frigidaire PLMV168
Good Afternoon Friend,
I understand that the display on your Frigidaire microwave, model# PLMV168, is dim and you are wondering if there is a way to make it brighter. There is not a way to make the display on your microwave brighter. That is the particular design of your appliance. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire PLMV168 Microwave Oven
When the microwave is cooking the light inside dims. When done cooking the light returns to full brightness. Is that normal or is there a problem with the microwave?
I've seen this with most microwave ovens I've had. When the microwave emitter kicks in to cook, the unit uses much more power, providing less to the internal bulb, which dims a bit. Unless it's very dramatic, for example the bulb turning off or going almost out, it's normal behavior. If the bulb is going very dim or out, it could be that the circuit it's connected to isn't providing enough amperage to adequately run the oven. In the case of your microwave, it's rated at 15 amps, so should have adequate power on a standard household circuit by itself.
Apr 09, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
I have a roper mounted microwave above my stove. i just need to know what kind of bulb goes underneath it.
Since you obviously intend replacing the bulb yourself (good for you!) you should first remove the old bulb and that will make it easier to find a new one. Chances are, its a common bulb, readily available wherever light bulbs are sold. Or, at the very least, a hardware store like Tru-Value or Home Base.
Feb 03, 2010 | Roper MHE14XKB Microwave Oven
Flickering lights
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 24, 2009 | Samsung MW5351G Microwave Oven
Covers over cooking/night lights are melting
I have a microwave above my stove also but it has not done what yours is doing. I would try a lower watt bulb since it would not give off as much heat. You may need to replace the lens or else just take it out and get rid of the problem altogether. You would have a brighter light anywas even if you kept the same bulb. Most of those bulbs are florescent and do not put out much heat anyway and seldom cause heat problems, esp. giving off enough heat to melt something.
Apr 17, 2009 | Microwave Ovens
Stove lights
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 13, 2008 | Microwave Ovens
Stove Light
try to fine the light switch in door and check the bulb
Sep 18, 2007 | Whirlpool MH7155XM Microwave Oven
Frigidaire FMV156D Microwave Oven Logo
70 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
