Fabric conditioner will not dispense from my lamona washing machine
Lamona washing machine
zeusfaber
  • 247 Answers
SOURCE: Fabric conditioner still in draw after wash cycle
This is usually a matter of pulling the drawer right out (it is designed to let you do this) and taking it to bits (it's designed for this too). Most front-loaders have a bit of a design weakness in that the bit that gets blocked with conditioner isn't immediately obvious without a little bit of prior dismantling. Once you get the top off the drawer, you'll almost certainly find the siphon tube gummed up with old conditioner. Clean this up under a hot tap, then reassemble and all should be well. A.
Posted on Apr 25, 2007
gittos73
  • 244 Answers
SOURCE: The fabric softner is not going into my washing machine
hi there just try washing the complete soap drawer again in boiling water leave in there for 10minutes to let the hot water work into the gaps and make sure u take all the holders out of the drawer u sometimes have to use a tooth brush to get into the small holes at the bottom of the little funnel what your softener holder goes over also get a small flat blade screwdriver and clean inside that funnel if thats not clean it will stop softener from going away if this doesnt work still then when your softener is supposed to be taken thru the programme make sure the washer opens the valve for the water to go into the fabric softener holder if it doesnt then the solenoid will need replacing as this could be faulty. LET ME KNOWHOW U GET ON PLEASE PETER
Posted on Nov 17, 2008
barkencoa
  • 3463 Answers
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Posted on Nov 25, 2008
bozcro
  • 867 Answers
SOURCE: Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
Posted on Dec 11, 2009
SOURCE: remove and replace fabric softener dispenser on kenmore model 20952992
I just did it. All you do is pull up on the blue part -- put the fingers of both hands under the rim and pull. It isn't screwed or bolted on. If there's a lot of gunk built up, it's all the harder to pull up. Be prepared for some yucky stuff. It would be nice if that whole section would come out, since you have to clean the area below with Q-tips.
Posted on Jan 09, 2010
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Fabric dispenser leaves water in dispenser after wash is done
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Why doesnt the fabric conditioner dispenser empty after each wash?
The softener dispenser is flushed with water as part of the wash cycle. The residual water prevents softener from clogging the dispenser between was cycles.
Aug 01, 2014 | Hotpoint Washing Machines
Fabric tray does not clear
Usually means soap dispensing drawer needs to be cleaned, as conditioner is dispensed by syphoning system, Take out soap detergent drawer, clean thoroughly in warm water, make sure drain hole in conditioner compartment is clear.
Nov 20, 2011 | Washing Machines
I have a AEG AKO LAVAMAT 6100 DIGITRONIC washing machine. The soap & fabric conditioner doesnt dispense.Can you help me please?
AEG AKO LAVAMAT 6100 DIGITRONIC washing machine. The soap & fabric conditioner doesnt dispense This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 04, 2011 | Washing Machines
The fabric conditioner drawer is not dispensing the conditioner in my Miele WT945S washing machine. I have taken the drawer out, clean it thoroughly and also the interior of the machine (where the drawer...
The fabric conditioner drawer is not dispensing the conditioner This video will show you how to keep your soap draw clear and how to service the parts
Feb 12, 2011 | Washing Machines
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
Dec 11, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Fabric conditioner not taken or not dispensed.
take out the drawer that the powder and conditioner goes in. the conditioner spout to allow the liquid to empty from the drawer will be blocked with a mixture of powder and conditioner. clear it thru with a sharp screwdriver or similar and wash under the tap. replace back in place should empty fine then. hope this helps.
Apr 12, 2009 | Washing Machines
Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Nov 03, 2008 | Miele W865 Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
