Question about Maytag Washing Machines
Not spinning correctly
Model #MVWC400XW3 clothes still wet when done washing. (only 1 year old). The top plastic ring that goes around the wash tub seems to be rubbing or wearing...Thought maybe that it's going out of balance.
  • 11 Answers
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Posted on May 20, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore washer
If your washer is not spinning fast enough, or barely spinning at all, this is usually a symptom of any one or all of the following: 1. Bad gearcase (transmission). 2. Bad basket drive, with which the transmission couples to under the agitator. 3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive. Usually a tell tale sign of a gearcase beginning to fail is the sign of an amber colored oil coated under the washer or inside the casing. I said, "usually". It doesn't always happen, but if you notice any signs of oil, the gearcase is shot. The basket drive and clutch assemblies are harder to diagnose and require some disassembly of the washer and the removal of the gearcase to inspect. Let me know if this helps.
Posted on Aug 02, 2007
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
  • 22 Answers
SOURCE: Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
Posted on Oct 21, 2008
  • 20 Answers
SOURCE: washer will not spin, will not spin in any spin cycle
Your water pump is clogged
Posted on Feb 10, 2009
I have a maytag top load washer (Bravos quiet series 300) that has stoped working. it flashes a code of "F51". It did this before and the repair man opened it up and found small clothing items...
Press 2 metal tabs. About 6" from the sides on the front of washer. Plastic ring on top has tabs that need to be disengaged to disconnect the ring. Once ring has been removed the area between the plastic tub & metal tub is accessible. Check for small articles of clothing, like socks or underwear. Inner tub can be removed by: snap up plastic cap (small slot for tool to slip in and pop up). Remove 7/16 nut and remove agitator (may require to be rocked back & forth, sits on a splined shaft). Remove 5 small phillips screws, being careful not to drop any, and pull inner metal tub up (may require it being shimmied back and forth). Removing this tub will give full access to any debris or articles of clothing that may be under it. Please keep in mind that if you're challenged in reassembly
Jun 16, 2017 | Maytag Atlantis MAV6000 Top Load Washer
My maytag atlantis cycles but wont spin out. It spins slowly then shuts off but leaves wet clothes and water in tub.
First determine whether all the water is pumping out before it goes into spin. If not, check the pump and drain. If its not spinning fast enough with an empty tub check that there isnt any article of clothing caught between the inner and outer tubs or tub top ring. If thats ok check the clutch by turning the main drive pulley CCW. Substantial drag should be felt before the basket overcomes momentum and begins to turn. There is no repair for the clutch on this machine. The transmission must be replaced.
Jul 14, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Top load washer about 8 years old- Problem 1 = during the finial rinse/spin the tub will not fulling drain and leaves clothes very wet...had a service call replaced the pump, however stills does not drain...
most likely its the electronic board, easy to change. if you can use a second hand one out of a known working machine- see how that goes- it will probably cure the noise problem
Sep 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Maytag top load clothes washer tub spins hard
Hi, You can unsnap the plastic splash ring and see if something is between the tubs. The inner tub turns rather hard anyways. The agitator might have a 1/4" screws in the side of it to hold it onto the shaft of the transmission. If not, just pull the agitator up real hard.
Under the agitator is a spanner nut that holds the inner tub in place. I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Maytag LAT3600A Top Load Washer
Clothing in between tub and will not spin at high speed on spin cycle i think i need to remove agitator to remove whatever is stuck around shaft and tub
Remove the cabinet.
Remove the plastic ring snapped to the outer tub.
Use a wire coat hanger to remove the garment.
Replace the plastic ring and the cabinet.
Mar 09, 2009 | Kenmore 22422 Top Load Washer
Mouldy mildew smell
I had the same problem and I fixed it fairly easily in about 45 minutes:
The root-cause is the incredibly stupid design of the plastic ring that snaps over the plastic wash tub. It is filled with many nooks and crannies that rarely contact the wash water, thus getting scummed up and moldy. See a picture of the gross mess here: http://www.falselaborblog.com/2008/08/moldy-maytag.html
The fix involves opening the top (easy) and removing the ring (fairly easy) and can be done yourself if you are the least bit handy.
Unplug the unit.
***If you are mold-sensitive, wear gloves and breathing apparatus or have someone do this for you.***
Tape the lid shut so it doesn't flop open when you raise the lid.
Use a putty knife to push into the front seam about 1 1/2 inch from each corner. This unlocks the top and it will open just like the hood on a car. Carefully secure this in the open position and don't let it fall on your head or your hands.
You will see plastic fasteners holding the top ring around the outer plastic wash tub. These will unsnap (you may need a flat-head screwdriver for some of them).
Carefully lift this out and try not to puke when you look at the underside (see photo http://www.falselaborblog.com/2008/08/moldy-maytag.html). Take it to a laundry tub or bathtub and thoroughly clean it by scrubbing with hot water, detergent and bleach.
Before replacing the ring, use a thin brush to clean between the upper part of the wash tub and drum---the scum and mold will be in here also.
Replace the ring in the reverse of the above steps.
Prevention: There is none. You will have to do this every 4 to 6 months to prevent mold from infesting all of your clothing, etc.
I'm experimenting with limiting wash load size to "large" and never using "super", reserving the "super" setting for running periodic (hot water + Clorox) to see if it reaches the idiotic upper ring and keeps it clean. I am not hopeful that this will eliminate the need for these overhauls.
P.S.: The person that designed this washer should have all of his/her underwear and bed linens washed in an uncleaned Maytag Atlantis for life.
Aug 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore Elite Oasis TL washer, stubborn Sd code
Found the problem. After removing the back panel, found some garments in the bottom of the surrounding clear plastic tub. These must have been periodically blocking the outflow area and triggering the Sd error code. Fixed it by opening the top components of the washer so I could see down into the surrounding tub from above. Fished out the garments with clothes hangar. Put everything back together and have done six loads with zero problems.
Mar 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Ok final Question
If this is a frigidaire, when the washer has a load in it, as the agitator agitates the tub should move about 1/8 of a turn. Meaning that for 8 agitations the tub should make 1 revolution. We call this indexing in the appliance repair world. If the tub is making 1 revolution in 4 agatations or 1 revolution in 1 agitation, the transmission is bad. This should have a 5 year warranty if purchased before 2006. You will also need a tub seal. Hope this helps
Feb 13, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
