Question about Yamaha RX-V373 5.1 Channel AV Receiver
Yamaha rx-v373 hdmi out red light - Yamaha RX-V373 5.1 Channel AV Receiver
  • 1894 Answers
SOURCE: Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
Posted on May 22, 2008
Benimur
  • 6966 Answers
SOURCE: Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 20, 2008
dunnbiker
  • 8546 Answers
SOURCE: Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Posted on Apr 27, 2009
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Posted on Mar 02, 2010
dunnbiker
  • 8546 Answers
SOURCE: Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Posted on Apr 30, 2010
No audio from my rx v373
hdmi cable does both vid and sound so you should be ok if you have used this way to connect. if you have used rca connection try using another red white yellow cable cause they are cheap and break easy.
Mar 29, 2014 | Yamaha RX-V373 5.1 Channel AV Receiver
Rx v373 firmware update
Usb crashes after playing several music and stops loading contents from usb. I had to turn the power off and on again to load. Is there any latest firmware for Rx v 373 yet?
Aug 16, 2013 | Yamaha RX-V373 5.1 Channel AV Receiver
Trying to hook up my wii but have sound and no picture I have HDMI cable from tv to yamaha v373 amp and trying to connect the red white and yellow cables to back of amp
Need to put yellow cable into monitor in and choose a input with video vcr, tv, or dvd. still no luck then yellow directly to tv.
Dec 08, 2012 | Yamaha RX-V373 5.1 AV Home Theater...
Yamaha purple screen rx-v373
I had this same issue. I think I finally resolved the issue by turning off HDMI Control (HDMI-CEC) on my Blu-Ray player. I had the Blu-Ray player plugged into a Yamaha RX-V375 (almost an identical receiver). I think the source of the issue was that my TV does not not support HDMI-CEC. Turning off HDMI-CEC on the Blu-Ray player fixed the issue. The Yamaha receiver already had HDMI Control disabled, and all the other HDMI devices appeared to have HDMI-CEC disabled or not supported.
In my case, the symptoms of the issue were that I would see the correct picture for a second on power up, then the picture would go away. For the Blu-Ray HDMI input selected on the receiver, I would see a solid purple screen and a blank screen for the rest of the inputs. Sometimes switching inputs fixed the issue, sometimes power cycling would fix it, but it was getting very annoying.
Dec 03, 2012 | Yamaha Audio Players & Recorders
Need manufacturer's setup code for Yamaha AV Receiver RX-V373
Using 1056B03 universal remote from Time Warner. Several codes actually will turn the unit off and allow volume control. Or..I can turn on and volume control. Can't do both. I tried to use the receiver codes in the vcr mode, but the remote rejects receiver codes (i.e. only accepts vcr codes).
It looks like one or the other, not both.
Jun 16, 2012 | Yamaha Audio Players & Recorders
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
Yamaha RX-V373 5.1 Channel AV Receiver Logo
96 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
