Question about Kodak i4200
ERROR CODE U7 - Kodak i4200
My sharp photocopier AR-M276 is showing error code U7-00. so what is the cause and remedy to it
Hi
U7-00 is pc/modem trouble, would you know whether you have a network port on the side of the machine, and whether it is connected to the network?. If you have and it is not connected to the network, that is what the error is, it is expecting an connection of some description.
if you go into settings on the machine, you can switch off the nic/tcp option, which should get rid of the error code.
Cheers
Andy
May 27, 2015 | Sharp Office Equipment & Supplies
CALL FOR SERVICE.CODE:U7-00
According to the error code manual, it means "U7 00 PC/Modem communication trouble" - You can download the entire list of all codes at the link below. It includes your machine specifically. Hope this helps. http://olsonbros.com/sharp/support/pdf_trbl/trbl-arm550n_m550u_m620n_m620u_m700n_m700u.pdf
May 27, 2014 | Sharp AR-M550U Copier
Xerox 5016 error code u70
Error U7, U7-1 (Photoreceptor Belt Drive)
Appears when the Copy Cartridge has Not Been Replaced.
Apr 27, 2011 | Xerox Office Equipment & Supplies
U7-45 xerox dc 440st
replace the drum unit
Mar 23, 2010 | Xerox DC440ST Copier
SHARP SF 2540 How to troubleshoot U3-20 and u7-00 ROMBLON
U3,20 - Mirror motor lock detection
U7 00 - Communication trouble between PC/Modem and the copier.
Seems to me the U3 error is something similar to the L6 errors in the slightly newer machines. It seems as though the laser moter in your machine has seized.
As for the U7, i have had this error out on the field before. Especially when the machine has had IP setting put into the machine but the network cable isn't plugged in. Throws up that bad boy =]
Aug 10, 2009 | Sharp Office Equipment & Supplies
Error Code U7 Light On Xerox 5328
Most likely the copy cartridge is the problem. There is one other thing to check though. There is a belt hole sensor mounted about in the middle of the upper **** shell of the machine. When you take off the upper front cover, it is a black assembly with 2, 5.5 MM screws holding it into the frame. It also has 2 high voltage wires running into it. Check to see if that is loose. Those screw holes will often strip and that sensor is out of position. If that is it. you can just replace those screws with the next larger size screw.
Just as likely though, is the belt is slipping or the sensor opening is blocked by dirt.
You can probably pick up a remanufactured copy cartridge for $200.
Look on E-Bay or google a business called The Parts Drop and give Britt a call. I dont work there. but have done business with them for years.
May 28, 2009 | Xerox Office Equipment & Supplies
Camera Code
mimi-griffin
pentax error codes are in the repair manual.the camera must be repaired . take the camera to a camera repair shop to get an estimate for repair.
Jul 04, 2008 | Pentax IQZoom 928 35mm Point and Shoot...
Kodak i4200 Logo
132 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
