Question about Kenmore KSM100 Stand Mixer
The whisk is broke,i need a new one - Kenmore KSM100 Stand Mixer
Why can't I remove the whisk attachment?
forgot to push up before turning possibly
Mar 21, 2016 | Cuisinart SM-55 Stand Mixer
How do I fix a wire prong on an egg beater attachment that has broke loose?
The wire whips are repairable but only by welding the whip back into place, that can be quite costly, and with new wire whips costing less than $20 that is the more economic solution.
Here is a link to the wire whips made by KitchenAid: Wire Whip MendingShed com Bowls Beaters Attachments
You will want to get your model number from the bottom of the mixer to ensure you get the correct wire whip. If you have trouble finding your model number in the chart be sure to contact us at Repairs Parts Kitchen Store MendingShed com & we will be happy to assit you.
- Colleen @ Mending Shed
Mar 08, 2015 | KitchenAid Food Mixers
Kenwood chef keeps curdling eggs
Put water in Kenwood and a bowl inside the Kenwood to hold eggs. Eggs need to be done SLOWLY. Can also add a LITTLE water to aggs as they cook to slow down curdling . Basically you need to turn Kenwood into a double boiler. Lift bowl with eggs in and out of Kenwood to control temperature and whisk away now under control. Lift bowl and cool and slow down cooking and lower back in water and Kenwood to hear back up. Keep whisking and lift and lower bowl as needed. Some melted butter doesn't hurt either!
Jan 11, 2015 | Kenwood Food Mixers
Kitchenaid whisk will no longer slip past the locking pin to rotate and attach on the spindle.
this might help... the whisk has a slightly larger whole then the other attachments. it is also inset. there is a washer that holds the spring on. if that is slightly off or bent it won't sit in the Whisks inset right. look a little closer to that and the spring. if there happened to be dried on food that could be the slight difference that can prevent it from staying one. Hope this helps!!!
25298509-2el2bftwapqh2uesegcwr3xp-2-0.jpg 25298509-2el2bftwapqh2uesegcwr3xp-2-1.jpg
Nov 27, 2014 | KitchenAid Professional 620 6-quart...
Whisk attachment is stuck on mixer.
I took a small crowbar, and put the curved end up inside the whisk, and hammered the other end lightly. After about 20 taps, the peg was lined up with the sideways opening so I could twist it off. When I got it off, it looked like there was either flour inside the part where the whisk attaches, or some light corrosion was going on. Either way, I'm going to put a little grease in there so it doesn't happen again.
Mar 09, 2010 | Food Mixers
Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Feb 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Whisk
Stove Parts Supply Ft. Worth Tx
Ecolab/GCS equip care
Sep 24, 2008 | Food Mixers
Parts for mixer whisks
need beaters for blck & decker mx230 hand mixer
Aug 16, 2008 | K-Tec Food Mixers
SILLY QUESTION
Push the whisk attachment post up into the mixer, turn counter-clockwise and it should lock into position.
Apr 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenmore KSM100 Stand Mixer Logo
20 people viewed this question
Top Kenmore Food Mixers Experts
Jim Thurston
john h
NOEL
NOEL
Are you a Kenmore Food Mixer Expert? Answer questions, earn points and help others
