Question about Advent Computers & Internet
Advent M112 wired mouse not working
My new advent m112 mouse with adapter does not work on my pc - another usb mouse and the adapter does work and the new advent m112 mouse works on another computer - so what's missing on my windows xp computer?
SOURCE: IFU-WLM2 sony USB Lan adapter is not working with Windows Vista
Try using the XP driver directly.
Posted on Dec 10, 2007
SOURCE: Computer Input Devices -> Keyboards and Mice -> Logitech RX1000 windows XP
knaif,
there are some wires of ur mouse that u cant see but damaged already..its in the wires..there might sum cires that were cut..
pls vote..
Posted on Apr 06, 2008
SOURCE: New wireless keyboard and mouse problems
Okay, it was as simple; hold the button on the reciever dongle for a couple of seconds, and the the same with the keyboard or mouse.
Why can't they just make the instructions clearer
many thanks Saigua
Posted on Aug 13, 2008
SOURCE: USB 2.0 cardbus pc card adapter N2PUCB
I bought this card to use with a dell 7500 laptop. The laptop does not have a usb 2 connection. I have tried various versions of linux, but my computer locks up whenever a device is connected to this card. It almost looks like the card has a power adapter port between the 2 usb connectors, however no power adapter was provided at the time of purchase from circuit city. Any ideas?
Posted on Oct 28, 2008
lea0101
  • 62 Answers
SOURCE: INSTALL XP ON EMACHINES M6811 WITHOUT CD
If you have another pc, network the two and share the cd drive of the other PC
Posted on Mar 07, 2009
Advent mouse not working
You need to install a software driver to make it work, normally Microsoft will recongnise a USB or serial mouse and install the driver for you.
If no,t take it back to whoever you bought the mouse from and ask them to install a driver, or to send you one.
Oct 26, 2013 | Computers & Internet
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
Cannot find the crank shift sensor location
M112 And M113 Engines
  1. Before servicing the vehicle, refer to the precautions.
  2. Remove air filter housing.
  3. Remove hot film mass air flow sensor.
  4. Remove air duct housing.
  5. Release and disconnect electrical connector at crankshaft Hall sensor.
  6. Remove bolt.
  7. Pull crankshaft Hall sensor out of crankcase.
    CKP sensor location
To install:
  1. Installation is the reverse of removal.
  2. Tighten crankshaft Hall sensor to crankcase bolt to 6 ft. lbs. (8 Nm).
  3. Carry out first initialization and then sensor rotor adaptation using Star Diagnosis tool.
Oct 22, 2010 | 2002 Mercedes-Benz C-Class
Does an advent ade-emb1 usb mouse require batteries in the mouse? i was using one with windows xp no problem then mouse optical light just stopped working help please
  • If it is a wireless mouse then it requires batteries.
  • In case if the advent mouse is a wired mouse then it doesn't require batteries.
Apr 06, 2010 | Computers & Internet
Replacing oil levl sensor due to oil leak.Is it urgent?
If the leak is small. just a couple of drops no problems.just check your oil level when u stop to get gas
Mar 08, 2009 | 1999 Mercedes-Benz E-Class
I have an Advent ADE-WLOI1 wireless mouse. Recently moved house and packed up my pc and mouse - now mouse won't work. Tried reset button - no go. My pc is virus infected and am trying to clean it - without...
This seems to be a generic mouse, usb / ps2 connectivity. User needs to press the connect / reset button on the receaver and on mouse. generally.. no drivers or cd required.
mouse has battery.
-check battery
-reconnect (receaver and mouse, if receaver doesn't have button, make sure its connected to pc and power is on, then reset.
try ps2 instead of usb or another usb port, might require adapter. (if im not mistaken it comes with the mouse)
-try another pc
= possibly faulty mouse if still not working? It should work with windows drivers, so no cd required.
Sep 23, 2008 | Computers & Internet
Advent ADE-EMBI mouse has stopped working even though both the USB light is on and the battery light is on. Can you help?
plz try with another mouse, if the new mouse is working then your old mouse is defective
Aug 05, 2008 | Computers & Internet
Computers & Internet Logo
557 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
