Question about Stihl Br500 Br550 Br600 Back Pack Blower Fuel Cap
Leaking oil on br600 leaf blower - Stihl Br500 Br550 Br600 Back Pack Blower Fuel Cap
How to adjust valves on 600 sthil backpack blower
BR 600 inlet valve = 0,10 ± 0,02 mm also 0,10 ± 0,02 mm exhaust valve
25894238-fwumhpxxuczdnoy1szymvc4h-5-0.jpeg Sorry only in Dutch
Oct 05, 2015 | Stihl Magnum Br600 Professional Backpack...
I am a 2 stroke technician an I am having a issue with a br600 stihl backpack blower. it runs great at high rpm but it will not idle when I get the idle set it idles down on its own a dies. Its under
the fuel filter is blocked up check inside the feed tank for a few leafs floating about and blockages
run the unit from a can of petrol to rule out a fuel feed issue
Dec 04, 2014 | Stihl Magnum Br600 Professional Backpack...
How do I replace a fuel primer build on the Stihl BR600 blower/
Disconnect the spark plug wire from the spark plug and ensure it can't come in contact with the spark plug. Removal of the spark plug wire removes any possibility that power can be supplied to the engine of the blower during the repair.
Remove the screws that hold the air filter cover in place. Remove the air filter cover and air filter. Remove the air filter housing from the side of the machine. Removal of these components allows you access to the primer bulb, fuel line and carburetor.
Repair Procedures for Stihl BR600 Backpack Blower Primer
Nov 03, 2014 | Stihl BR600
Why does my leaf blower lack power
Could be worn plug,bad gas,dirty air filter.Don'y buy your plug from stihl,too high ,go to autozone.The filters you have to get from them,i use there oil mixture,
Oct 16, 2014 | Stihl Magnum Br600 Professional Backpack...
Motor quit runing and now it has no compraison
the piston rings are gone
prob you put too much oil in it????
im afraid its a gonner unless you rebore it and change the piston and rings set
prob the top and bottom bearings
its for the bin
however i would donate it to any local service shop and its organs can live on
Apr 11, 2014 | Stihl Magnum Br600 Professional Backpack...
Gas cap leaks
the seal is missing youve dropped it in a garden somewhere
you need a new one
try ebay
but i will tell you stihl is VERY good at service parts
and very helpfull
http://www.ebay.co.uk/itm/PETROL-FUEL-TANK-CAP-FITS-STIHL-BR500-BR550-BR600-BLOWER-/141346840553?pt=UK_Home_Garden_GardenPowerTools_CA&hash=item20e8ed9fe9
Feb 19, 2014 | Stihl Br500 Br550 Br600 Back Pack Blower...
Ignition module gap setting
look up the manual on the stihl site
it tells you this detail
Dec 05, 2013 | Stihl Magnum Br600 Professional Backpack...
Backpack blower runs on choke only
replace fuel filter
air filter
spark plug
and clean the carborator jets etc...
change/change out the oil and measure the amount you put in
by the manual info look on the sthil site for the manual
Nov 13, 2013 | Stihl Magnum Br600 Professional Backpack...
How to set the timing on sthil blower br600
you can only adjust the coil to flywheel gap... timing for the flywheel is preset and un-aqdjustable
Aug 31, 2013 | Stihl Magnum Br600 Professional Backpack...
Stihl Br500 Br550 Br600 Back Pack Blower Fuel Cap Logo
29 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
