Question about Ovens
Firenzi electric oven fsf 650 not heating
The oven is not lighting up or heating. The grill is working
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
barkencoa
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
  • 69 Answers
SOURCE: my omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Posted on Mar 18, 2010
heatman101
  • 43501 Answers
SOURCE: Top oven (and Grill) have stopped working
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Heating elements in fan oven not working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 26, 2011 | Smeg Ovens
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jan 14, 2011 | Smeg Ovens
Zaunssi ZBF360X built in Oven Not Heating
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
Zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Feb 10, 2010 | Ovens
Burnt some food yest in grill and is not working today. wouldnt turn on straight away so i left it till this morning but still not heating up. oven is working perfectly fine. could the heating element for...
if the temp light or indicator light for the grill is on then i'm tempted to say that it is the element but checking for resistance is the only sure way to know..
Dec 22, 2009 | Zanussi ZBF360 Electric Single Oven
I Have a firenzi oven, the electric went off ,
I have exactly the same problem. I found out that you could hold button 2 down while turning power on, but this didn't work for me... var viewReq = new Array();function vu(u) {var i=new Image();i.src=u.replace("&","&");viewReq.push(i);} vu("http://googleads.g.doubleclick.net/pagead/adview?ai\x3dBQHenXgRHTarfAc6m8AO8mtSYDM-1tesBl4qClxel7-_HBAAQARgBIAA4AVCAx-HEBGC7vq6D0AqCARdjYS1wdWItMzM4NDk0NjI4NTM1MTk1NqABx5L46gOyAQ13d3cuZml4eWEuY29tugEKMzAweDI1MF9hc8gBCdoBSGh0dHA6Ly93d3cuZml4eWEuY29tL3N1cHBvcnQvdDM2NzY3OTAtZmlyZW56aV9vdmVuX2VsZWN0cmljX3dlbnRfb2ZmX3JfbpgC1AepAp9IXDEvwbo-wAIByAKxu74N4AIA6gIkNjE1My9maXguaG9tZWdhcmRlbi9tYWpvcl9hcHBsaWFuY2VzqAMB6AONCugDjwL1AwAAAATgBAE\x26sigh\x3dKqwNoW_2lVE") body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; }
Dec 20, 2009 | Ovens
Smeg oven
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Ovens Logo
48 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
