Question about Dell Studio Xps M1330 Webcam Board Cable N6704 Cn-0n6704
Which interface has the Cn-0n6704
Is it usb or not
What Are Similarities and Differences Between Console and Mini USB Interfaces?
A console interface can be connected to an operation terminal for onsite configuration. It must be used with a console cable. After a switch is powered on for the first time, you need to log in to the switch through the console interface to configure the switch.
A Mini USB interface is also used to connect the switch to an operation terminal. The Mini USB and console interfaces on a switch are multiplexed and enable connection to the switch through different types of physical interfaces. Only one of the Mini USB and console interfaces can be used at a time. The Mini USB interface is preferred.
Apr 21, 2016 | Computers & Internet
Hi I have a Panasonic cn-h500d I would like to know if I can change the language from Japanese to English
It appears to be made for the Japanese market.
Panasonic will launch two new GPS systems in the form of the Strada CN-H500WD and CN-H500D. These in-dash car navigation systems feature "Motion Control" user interface, allowing you to manipulate the map with hand gestures. Both navigation gadgets also provide an integrated DVD/CD player, a 7-inch (800 x 480) LED-backlit touchscreen display, a 1Seg TV tuner, SRS WOW HD, a 60GB of internal HDD and the Panasonic PEAKS image processor. The Panasonic CN-H500WD and CN-H500D will be available in the Japanese market in August 2011.
Putting that model number into Panasonic Support search only brings up details in Japanese.
http://vftr.panasonic.co.jp/en/search.x?q=cn-h500d&searchIn=&_charset_=utf-8
Oct 22, 2015 | Panasonic Cameras
How do I connect my CAD GXL2200 mic to my apple laptop?
You need a USB interface such as an M-Audio M-Track and a standard XLR male to female audio cable.
You use the cable to connect the microphone to the interface using the XLR cable, then you plug the USB cable on the interface to a USB port on your laptop. Finally, you go to System Preferences - Sound - Input and select the USB interface as the input source.
Depending on the software you you use for recording sound (I use Sound Studio from Felt Tip Software) you may need to go into the Preferences for the program and select the USB interface.
Dec 25, 2013 | CAD Microphones GXL2200 Professional...
Epson lx-300 parallel to usb printing problem
Make sure driver for Parallel to USB adapter is installed properly, this doesn't guarantee that it will work. Suggestion is, check for interface availability for Epson printer if you can change parallel interface at the back of it to USB interface. Call Epson for details and availability.
Sep 21, 2012 | Epson LX Office Equipment & Supplies
Don t setup drives e-mu 0202 usb win 7
Without knowing more about the problem, I can only give you the holy grail of information for the EM-U 0202 Go to the link below for all you could ever want.
http://ask.emu.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=creative_emu,U={B8F60310-DA4F-11D3-94F4-00500463020E},Company={39C0DC6D-57B0-4A93-9950-938920B4A34D},d=1211880325312,VARSET=centric:1005,VARSET=m:0,VARSET=c:0,VARSET=pn:0202%20USB%202.0,VARSET=cn:Interfaces,VARSET=catfaq:CATFAQ_25,VARSET=prodfaq:PRODFAQ_1005
May 14, 2011 | Creative Labs EMU 0202 Sound Card
Son wants to buy CAD GXL2200sp studio microphone package and wants to plug into laptop.Will that work?
for purposes of recording quality, I would recomend getting and external sound card. M-audio make a good range. You would need to have a +48v phantom power supply for this unit to work. The sound card you buy should have this. A Pc or laptop won't
Jan 16, 2011 | CAD Microphones GXL2200 Professional...
When you turn on the Air conditioner, the letters HL with ! light up.
Condensate pump float switch risen. Check drain pan is empty, check pump is working OK. If no pump check blue jumper plug is inserted in socket CN Float.
Alternatively, Dry Contact Interface is in "OFF" condition. Check status and adjust as necessary.
Jan 09, 2011 | DeLonghi Heating & Cooling
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    Dec 23, 2010 | Intel DG31PR Motherboard
    I download d driver of hp 3535 od....but hw cn i install it? v dunno whether i install it od....cn u tell in d install procedur so tat i cn check.....
    kindly uninstall the printer driver if you already install.and restart the system and don’t connect the usb cable ,1st install the driver which you downloaded from the internet and when it prompt you for connect the usb cable then connect it and follow the instruction.
    Jan 08, 2010 | HP DeskJet 3535 InkJet Printer
    Dell Studio Xps M1330 Webcam Board Cable N6704 Cn-0n6704 Logo
    mukhtar21 shaikh
    mukhtar21 shaikh
