Question about Conair GS23 Jet Liner steam hand-held garment steamer
When turned on and running there is no steam - Conair GS23 Jet Liner steam hand-held garment steamer
How do I get the boiler on my rowenta steam generator to fill? I was given this model.
You should only use distiller water in the steamer. Never ever use tap water! This is what caused lime and scale build up.
Since it's to late, you have nothing to loose by trying this to descale the unit:
Put up to one cup of white vinegar into the reservoir. Fill 3/4 of the way with water. Turn unit on and let it heat up, but DO NOT RUN STEAM THROUGH THE LINE. Once heated up, turn unit off and let it set for hours. Drain and rinse well. Then run a water only batch through the steam cycle. There are companies that sell special de scaling solutions. But hopefully, the vinegar will work.
Apr 25, 2014 | Rowenta Steam Generator DG050 Iron
How to flush brown fluid water from Sunbeam Steam Master
Run a tank of 50/50 water and white vinegar through the steam cycly. Run two or three more tanks of plain water. This should clean it out safely.
Mar 13, 2013 | Sunbeam 4214 Iron
It's clogged up and want steam.
I don't have that particular model but my Rowenta as a self cleaning setting.
However, I am going to assume yours does not have that feature. In a jar or pitcher, mix 1 cup of vinegar and 1 cup of tap water. Pour that into the reservoir and allow it to sit an hour, then turn on your Rowenta and with lucky you should see some steam. If so allow it to steam ... checking it often to make sure nothing is being damaged by pressure or over heating. If you run out of solution before the iron is steaming correctly... repeat. It may take a few tries at this before you get some serious steam.
Feb 26, 2013 | Irons
My Rowenta Master Steam Generator - Steam button turns on but does not turn red or heat.
- First the good news, the service center in Concord is very good and would you believe they have new in the box Rowenta DG980 in stock!
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Now the not so good news. This model uses what I call a "flutter pump" that turns on when the boiler needs more water pumped in if the reservoir is dry and the red light comes on indicating it is out of water.
Generally, if you remove the blue water reservoir and turn on the unit, in about 5 minutes the boiler should have sufficient heat converting the residual water in the system to steam, for at least one or 2 "bursts of steam".
If all this works, then likely the $75 electronic printed ckt board driver detector is okay. It enables the flutter pump, fills the boiler with a few tablespoons of water to be converted to steam and repressurizes the steam system. It is the sequence logic this board does that you can use to determine the bad part, find and replace it yourself. There are many thermostats and sensors and without a schematic it is tough to reverse engineer.
The most expensive parts are the tank heater and sole plate elements followed by the ckt board (make sure you label all the connections & draw a color coded diagram before replacing this part) especially likely if the flutter pump does not turn on and everything else gets hot & steams is okay if unit less than 5-10 yrs old. BTW a new unit is $350 so you have to weigh your options and talk estimate for repair with repair tech if you go that route. A lot can be said if your unit is not that old, have used clear water, allowed steam to run dry (minimizing long term storage with water in unit), and cleaning the boiler as specified in manual. It is worth the price to repair OR replace. It is a great machine.
May 16, 2010 | Rowenta DG-980 Iron
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
How to use steam iron
Fill the iron with equal parts white vinegar and distilled water. Place an oven rack over your sink and position the iron on top, with the steam vents facing down. Plug in the iron and turn it to the steam setting. Run it until the steam stops.
Feb 23, 2008 | Micro Pro 7599 Iron
Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Nov 15, 2007 | Irons
Conair GS23 Jet Liner steam hand-held garment steamer Logo
23 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
