Question about Toys
Thomas the train circuit board- replacement- I need a new one and tried to find one at tigerimports.net They show nothing. But readers have said they ordered one from them. Please help me find one
I need to know where and how to order a circuit board for the thomas the train ride on toy with tracks. THank you
5 Suggested Answers
  • 80 Answers
SOURCE: Peg Perego Thomas Train Track Rider
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Posted on Mar 24, 2009
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
Posted on Jun 01, 2009
  • 567 Answers
SOURCE: where to find thomas the train instructions
on the box it should state manufacture contact them and ask for the instructions should be no problem
Posted on May 23, 2010
adamfjeld
  • 1508 Answers
SOURCE: i need to replace the motor in my thomas ride on train but can't figure out how to get it apart - suggestions?
you'll have to pull the rear wheels off then pull the motor off of the axle
Posted on Dec 14, 2012
Help please. Lionel (30190) Thomas & Friends remote O gauge. Train won't move. Light comes no, nothing. I took the roof off and made sure the switch was in the on position. ??
First, check to make certain that the batteries in the remote are good.
Second, if the train has been running and the problem is new, clean your wheels and pick up roller on the locomotive, then clean the track.
Make certain that when you use the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If none of the above helps, contact the Lionel Service Department.
586-949-4100
Oct 07, 2013 | Lionel (31956) Thomas The Train Set
I have the Peg Perego Thomas the Train Track Rider; when I press any of the two red buttoms on the train, I only hear a train whisle and train music, but the train does not move. It is fully charged and I...
first of all check for at least 6 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the plastic housing on the top and verify that both the positive and negative wires are plugged in
Nov 27, 2012 | Toys
Hi we have a peg perego 24 volt Gaucho 2 seater jeep. We know that it needs a new circuit board but have no idea where to get one. Please could you suggest somewhere? Kind regards Elaine
You can order the part on the link below. This board is for the Gaucho Superpower jeep if that is not what you have then go to the second link to find your jeep.
http://www.tigerimports.net/sunshop/index.php?l=product_detail&p=7165
http://peg-peregoparts.com/
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 18, 2010 | Peg Perego Gaucho Superpower
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
Jul 15, 2009 | Peg Perego IGED1084 Santa Fe Train
Hi
May 28, 2009 | Learning Curve Toys Thomas the Tank Engine...
Mar 12, 2009 | Toys
Need Diamec 6V 4.5AH battery charger for Thomas the Train
Call peg perego directly. You want to make sure you get the correct one , you can mess up the battery with a slightly different charger.
Jan 12, 2009 | Peg Perego IGED1084 Santa Fe Train
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Dec 16, 2008 | Peg Perego Vespa Scooter
Ride on thomas peg-perego
Sometimes the battery and/or the charger can go bad. If the battery is less than 6 volts on a multimeter, it won't operate for long. Is the headlight bright or dim? Remember that the button has to be held down to run. Releasing the button will stop the train.
If neither of the above works, you may want to order a new circuit board from tigerimports.com.
Jul 29, 2008 | Toys
Toys Logo
93 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
