Show a connectioin diagram for a century d1036
I have a d1036 century motor, it have 3 wires for low-red med-blue and high-black then it also have yellow /brown/ brown-white...how would I wire this
pierre1811
  • 144 Answers
SOURCE: I have Bryant HRV and the motor has failed.
Wire nut and tape the blue and red wires they are not used.
Posted on Mar 06, 2009
farfield
  • 462 Answers
SOURCE: RV AC, how to wire fan (blower) motor to capacitor.
You almost have it Look closer at the run capacitor. It has Herm, this is for the compressor, Com or C and F or Fan.
1 of your power wires is the fan speed so connect them accordingly usually black is hi, blue med, & red is low. You are "feeding" voltage to the selector switch on 1 side and coming out to the fan motor speeds.
Next you have a "Common" wire on your fan motor (this means its Common to all the other connections inside the fan motor to me. It is usually white. Connect this to the other line of power usually the Com on the capacitor unless it connects to a strip on the selector switch. But 1 of these 2 places will be the other side of your Power when plugged in. Lastly the brown it is usually the fan capicator only wire and it will connect to the fan "F" terminal on the capicator this terminal will not have any other wires connected to it.
This should make you a happy camper. Please rate me accordingly and good luck.
Posted on Mar 08, 2009
  • 587 Answers
SOURCE: I am replacing the a/c
Motor Wiring
Old Motor
Brown wire is Start
Yellow wire is run or Power
Black wire is High Speed or Common
The other two taps are speed taps, but you have a single speed application
And high speed is what you need ,that’s why there’s not any wires
on Red and Blue if high speed was to much then you would move the
Black wire to one of the other taps RED low speed or Blue Medinm speed
New Motor
White goes to the Yellow wire from the capacitor
Black goes to the Black wire you took off of high speed on old motor
Of course both Brown wires go to the capacitor and Green to ground
If a capacitor doesn’t discharge it doesn’t mean it’s bad
but the capacitors don’t last as long as they used.
Any time you put in a new motor always replace the capacitor
It will save you a lot of time and grief later on.
Posted on Apr 28, 2009
  • 21 Answers
SOURCE: told motor was bad, replaced motor, new motor does not run
Black to Black, Purple to White and the new motor requires a run capacitor which brown goes to one side of capacitor and brown/white goes to the othe side of the capacitor. This is providing the old motor is a single speed. If the old motor is a two speed you have an incorrect replacement motor.
Posted on May 02, 2009
  • 79 Answers
SOURCE: I have an a/c unit that is blowing on high
The reason the a/c is on the high speed is to move the air because cold air is harder to move, slowing down the speed may cause your a/c to freeze-up. You can try changing the speed by reading the wiring schematic, take your time to become confortable with the schematic, and it will tell you which wire color conforms to each speed, locate the high speed wire color, and you will find that connected, locate the medium speed wire color, then disconnect the high speed and reconnect the medium speed wire in it's place. Be sure to tape the end of high speed wire so that it is insulated from the cabinet. ABOVE ALL MAKE SURE THE POWER SWITCH IS OFF BEFORE ATTEMPTING THIS
Posted on Jun 23, 2009
Replacing home a/c blower motor the unit has black and white wires my new motoe has blue lack red and yellow wres How do i wi it?
DO YOU HAVE A WIRING DIAGRAM OF THE NEW MOTOR? TYPICALLY NEW MOTOR WILL HAVE OPTION FOR MULTIPLE SPEED MOTORS.
WIRES ON UNIT NEW MOTOR
WHITE.............................NEUTRAL.........WHITE
BLACK ...........................HOT...................RED=LOW
OPTION 2 YELLOW=MED/LOW
OPTION 3 BLUE=MED/HI
OPTION 4 BLACK=HI
Dec 09, 2014 | Heating & Cooling
Where do the 3 wires from the blower motor connect to on the control board for high speed use in the summer time? Black, Blue, and the Red one? The white is a no brainer. I can go to M1, cool, and heat....
Hello, the black wire is your high sped motor tap and it should be on cool as you have it. Blue is med-hi and red is your low speed motor tap. You have it wired correctly. Now the freezing can be caused by 2 things, low airflow or a low refrigerant charge. Low airflow can be caused by a dirty air filter, dirty evaporator coil, dirty blower wheel or the blower itself is running slow due to a weak capacitor. Anytime the motor is changed out the capacitor should aswell. If the airflow appears to be ok then the unit is low on refrigerant.
Jul 11, 2012 | Heating & Cooling
I have an Emerson (4 Speed) direct drive blower for my gas furnace. What is the process (wire color codes) to change speeds on the blower. (I have a red, black and yellow wires taped off in the wire...
There should be a wiring diagram on the motor itself. The colors of the wires vary depending on voltage and model. Generally you have a med/low and med/high setting, I'm not sure what you are getting to with the low/high setting unless you are trying to set up staging. Check the motor for a diagram, if that is not present post back with all of the wire colors coming from the motor and the voltage.
Sep 25, 2011 | Emerson Heating & Cooling
Replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Kitchen Appliances - Others
Need connection diagram, AO Smith motor FDL 1056
Black is high , Blue is med. , red is low
Feb 19, 2009 | Heating & Cooling
Blower speed
Yes usually the black is high speed, the blue is low and red medium speed. plug the black wire from the fan motor to where the blue wire is, then put the blue where the black wire was
Jan 10, 2009 | Intertherm P3RA-048K Air Conditioner
My blower fan came off the motor shaft.
THE BLOWER MOTOR HAS 6-WIRES ....2--CAPICATOR (BROWN- BROWN WHITE STRIPE)3- SPEEDS BLACK-HI-SPEED--BLUE--MED......RED--LOW SPEED OR HEAT AND THE LAST ONE TO COMMOM.
Nov 23, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
241 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
