Question about Porsche Design Clothing Accessories
Need nose pad for Porsche p 8000 - Porsche Design Clothing Accessories
Need nose pad replacements for P-8458 model. Where can I get these?
I have the same problem. If you found where you can get these, please email me, scott@iisystems.com. I'll do the same if you send me your email address.
Thanks...
Mar 31, 2011 | Porsche Design Clothing Accessories
Hello, I have Just Cavalli JC225 glasses. They were too tight and the arms were widened, to stop the glasses being pushed forward. Now they rest too heavily on my nose, causing red marks and...
There are a couple of things that can be done to fix this problem. One of the easiest solutions is to have the nose pads replaced with larger and/or softer nose pads. Alternatively, a saddle shaped nose pad can be helpful in distributing the weight across your nose. Most local optometrists should have nose pads available that they can change out for you.
Furthermore, if the nose pads are set at a bad angle they can dig into your nose also. Adding some curl to the end of the arms can bring the glasses closer to the face if they are sitting too low. If you are careful you can attempt some of these adjustments yourself.
Feb 25, 2011 | Roberto Cavalli Just Cavalli JC225 097...
I need two replacment nose bridge pads for a Kate Spade 135 EMME 1/S KADP. Where can I get them?
you can get the nose pads from any opticians, and they only cost a few pence each,
hope this helps
Feb 03, 2011 | kate spade Emme Sunglasses
Porsche boxster
Hi
The pads may need adjusting,,,,But the physics will tell you that when the pad is wet...there is reduced friction which can be perceived as a worn out pad....
Genius Guy
Oct 16, 2008 | 2001 Porsche Boxster
Clothing Accessories Logo
51 people viewed this question
Top Porsche Design Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Porsche Design Clothing Accessory Expert? Answer questions, earn points and help others
