Question about Faby Cab S.p.a Faby CAB Frozen Drink Machine 2 Bowl
Cab Faby Not Freezing - Faby Cab S.p.a Faby CAB Frozen Drink Machine 2 Bowl
  • Faby Cab S.p.a Master
  • 2,236 Answers
Could be any number of things: mixture being too rich (add more water), timer is off (reset defrost timer on side), 4-minute timer is not turning on compressor (inside right front panel. unplug thin blue wire harness, turn middle screw until compressor turns on), the refrigeration solenoids (is there a click from the back when you turn the switches on), does the compressor turn on, does the fan turn on (if there is no air flow, the overpressure sensor will turn the compressor off), or maybe there is a leak. if it is the last case, you will need a professional to take a look at it.
Posted on Jan 03, 2015
Faby 2 slush machine spiral blades won't turn
why is this posted in cars and trucks???
May 08, 2017 | Cars & Trucks
Faby 3 slush machine over freezing
Assuming the mix is mixed correctly and the auger is turning, make sure the micro switch to the right of the motor in the back is in place correctly and works ok. That switch tells the freezing to stop.
Jun 13, 2015 | Faby Cab S.p.a Faby CAB Frozen Drink...
How do i know if thermostat is bad
depends on the slush machine. if it's a cab or ugolini, it won't go into defrost or it'll just go warm instead of refrigerated. easy way to test on a cab faby- put the timer on defrost when the product is not frozen, turn the right auger on then off. if the compressor did not go on and off, the thermostat is bad. same for a ugolini, but it'll work with both sides, so turn one off. if you have a bunn ultra 2, the display will let you know there is a thermostat issue. if you have a bunn cds 2, it works the same as a ugolini.
Sep 03, 2014 | Kitchen Appliances - Others
Repair
try allen associates in rochester, ny.- allenprograms.com
Jun 06, 2014 | Faby Cab S.p.a Faby CAB Frozen Drink...
Where is the reset switch on a slush puppy machine
cab faby? on the right front panel towards the bottom and behind the sticker there is a hole. inside the hole is the reset button.
May 30, 2014 | Kitchen Appliances - Others
Why is slush machine only freezing on one side
if it's a cab faby and it's the right side not freezing but getting cold, you have low refrigerant. if it's warm, you have a stuck solenoid, blocked capillary tube, or a bad torque micro switch. if it's a bunn ultra 2, you have a bad solenoid or the freezing button is not on freeze.
May 16, 2014 | Kitchen Appliances - Others
My faby slush machine is freezing up
mix too lean. add a bit more base. also check the torque switch next to the stir motor. if it's stuck open, it won't stop freezing
Apr 02, 2014 | Faby Cab S.p.a Faby CAB Frozen Drink...
My fridgedaire fridge is freezing my food. were do i start looking and how do i test?
check wiring harness between bottom of cab and bottom right hand freezer section for wear and tear.
Feb 27, 2010 | Frigidaire FRS26H5AS Side by Side...
I cannot get my 2002 Dakota Quad Cab out of park in cold weather. When the outside temp gets above freezing, it will go into gear. The safety mechanism is not disengaging when I put on the brake to shift...
sounds like some **** on the line used the wrong grease and is isnt allowing the sable to slide frr in the case remove cable and clean with brake sleaner to disolve grease
Jan 15, 2010 | 2002 Dodge Dakota Club Cab
F150 FWD
did you lock your hubs or are they auto?
Dec 20, 2008 | 1995 Ford F150 Styleside Regular Cab
Faby Cab S.p.a Faby CAB Frozen Drink Machine 2 Bowl Logo
818 people viewed this question
Top Faby Cab S.p.a Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Faby Cab S.p.a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
