Question about Arrow Fastener 509 9/16" T50 Staples
How to put the sprin back in the t-50m staple
I just can't how to put the staple in the gun. I pulled the chamber to put the staples in?
On most staplers there is a long spring with a metal tab at the end. Push back the tab and compress the spring and put the staples in front of the tab.
Jun 16, 2017 | Staples Tools & Hardware - Others
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
Need to get new pressure push bar to hold staples in placeto be feed into gun no T-50M
http://www.amazon.com/Arrow-Fastener-Staple-Parts-PK50/dp/B00004Z2IG/ref=sr_1_10?s=power-hand-tools&ie=UTF8&qid=1307995590&sr=1-10 hope that helps.
Jun 13, 2011 | Arrow Fastener 509 9/16" T50 Staples
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
Can't get the staples to go in. It's a sears
Pull out the part that loads the staples, turn the gun upside down, put the staples in the bottom of the gun and push the loader back in. It took me awhile to realize that you don't load them on the piece that pulls out of the gun.
Cheers.
May 10, 2009 | Tools & Hardware - Others
My arrow fastener model t-50m is jammed how do I remove the few
I have a similar issue with my T50m stapler. To remove the staples unscrew the locking nut near where you load the staples and remove the tapppered bolt. The track will lift out and the staples can be easily removed. Why this is happening is unknown to me also. I purchased a new gun.
Feb 14, 2009 | Arrow Fastener 509 9/16" T50 Staples
Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Dec 03, 2008 | Ace Hardware Ace Staple Gun
LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Nov 08, 2008 | Powerfast Stanley TR110 Light-Duty Staple...
Refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Oct 10, 2008 | Arrow 8000 Power Shot Pro Staple & Nail...
Arrow Fastener 509 9/16" T50 Staples  Logo
21 people viewed this question
Top Arrow Fastener Tools & Hardware - Others Experts
Are you an Arrow Fastener Tool and Hardware - Other Expert? Answer questions, earn points and help others
