Question about Infinity BASSLINK Car Subwoofer
No power
Power going to Basslink no power coming out
  • siwong555 Nov 07, 2008
    Okay my basslink has no power at least I don't think it does. I installed it the way the instructions said but the power led light don't come on and no bass...nothing. So is there any way I can get this checked out? or can someone help me with this. Can i connect the remote wire to the antenna wire. does the blue and white wire on the radio harness have to be connected?
What wire for the auto on? I'm having a same problem
Posted on Nov 07, 2008
If the l.e.d. light is not coming on check the auto on swich. also if there is no wire going to the suto on that may cause it not to turn on
Posted on Feb 25, 2008
Infinity Basslink. I wired and connected everything and sounded amazing. I removed my center console to construct a box to put the Basslink in. When I was putting the Basslink sub into the box (tight fit)...
I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Jan 17, 2014 | Infinity BASSLINK Car Subwoofer
Power light
Hi Bill, I believe the power problem is related to the Remote wire which should be blue or yellow. The remote wire is suppose the turn the Basslink on and off when the radio is turned on and off. The yellow wire is normally used for power antenna. Traditionally the remote wire is blue. You can use a Speaker level adapter and splice in with the L/R rear speaker wires, and the adapter will convert the speaker level to line level. The output of the adapter will go to the Rear speaker input on the basslink., Write back if you need more detail on the adapter.
Oct 07, 2007 | Infinity BASSLINK Car Subwoofer
My basslink circuitry is fried!!
go to the website that built the part. they usually have manuls you can download and get exact part number.. then go to ebay or google t for fix andddd parts cosr
Feb 17, 2010 | Infinity BASSLINK Car Subwoofer
Is the light on the infinity basslink suppose to be red or green
Hello jmw3031,
The Basslink should have both a red power LED and a green servo LED. The red LED should be on when power is applied. The green servo LED should only come on during high-level bass transients. Turn the gain down slightly if it stays on for extended periods.
Hope this helps.
Jul 15, 2009 | Infinity BASSLINK Car Subwoofer
Basslink Powerlight comes on then fades quickly
check to make sure your remote wire is hooked up to your amp turn on that runs straight out of the stereo not your power antenna also make sur you have a clean ground(no paint or rust) and also check your connections make sure you have a strong connection to all wire hook should check to see that your remote wire has no tears in it or small rips or cuts because that can interrupt your current to and from the amp and radio
Jun 25, 2009 | Infinity BASSLINK Car Subwoofer
Infinity Basslink killing battery
Both issues sound like they are related to a non-connected or loosely connected remote wire on the Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
Mar 19, 2008 | Infinity BASSLINK Car Subwoofer
Infinity basslink is messed-up
You may have blown the fuse in the AMP. Check it and let me know.
Jan 15, 2008 | Infinity BASSLINK Car Subwoofer
Basslink "Motorboating"
Good evening, my name is Colmen here is a guy that might be able to help you 917 504 0461 please let me know how you make out, he has done a lot for me, by the way his name is Cee...
Dec 19, 2007 | Infinity BASSLINK Car Subwoofer
No power
Other than the +12V, the ground (-) and the 2 RCA inputs, normally external amps have also a remote trigger which switches it to active on. The remote trigger is activated by a wire from the head unit. Colors would either be yellow or blue but depends on manufacturer of head unit. Alternately, you can connect a simple toggle on/off switch to activate the external amp.
Additionally, pls verify that the 2 RCAs from your head unit are audio out and not audio in for aux source.
Good luck and kind regards.
Nov 01, 2007 | Infinity BASSLINK Car Subwoofer
Basslink drops out.
The auto on switch should only be in the on position when the REM wire is NOT connected. Auto on can be flaky. Basslinks respond better to RCA inputs then the high level ones. You might try getting an RCA line converter, they work very well with the Basslink.
Oct 02, 2007 | Infinity BASSLINK Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
143 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
