Question about Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
Need a homestead hp 4000 ceiling fan remote control
Remote control needed
2 Suggested Answers
SOURCE: Light not working by pull chain or remote.
I would try removing the remote part. Connect the two main (light & fan) wires direct to your house main. Then if the pull chain works then you just need a new remote unit.
Posted on Apr 07, 2008
Remote control B-542
Peter, Home Depot carries replacement ceiling fan remotes.
Check the attached links,remote and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Universal Hunter Ceiling Fan Remote Control Replacement Light Fan Speed...
Hampton Bay Ceiling Fan Remote Control 70830 The Home Depot
Jan 28, 2013 | Dryers
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I need to replace my Hampton Bay Ceiling Fan remote control. Part # G9P2BTAUC7052T. Where do I get one?
I need to replace my hampton bay remote control part #G9P2BTAUC7052T for my ceiling fan and light.Where do I get one
Jul 11, 2011 | Universal Remote Control Hampton Bay...
I have a Hampton Bay Remote Ceiling Fan but Remote is missing. Where can I get one.
1. try ebay
2. stores sell universal remotes that can work most ceiling fans.
Apr 13, 2011 | Universal Remote Control Hampton Bay...
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
My ceiling fans original remote is broken adn I need to get a code to set the universal remote to turn on/off my fan
While it's true a lot of ceiling fan remotes and receivers are universal, there are exceptions. Obviously you need a dedicated ceiling fan remote, not something picked up at a local wal-mart that controls t.v.'s and dvr's. I would need to know what kind of system you have. One of the most common types is a UC7067 4 dipswitch (64 -bit) sytem. Look in the battery compartment of your remote for 4 tiny micro switches this will let you know. If you have this system, you can get replacement parts from www.fanmanlighting.com or call them at 1-866-600-3267
Oct 15, 2009 | Universal Remote Control Hampton Bay...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Heritage (5BUW52WZ4HN) 52'' Ceiling Fan Logo
22 people viewed this question
Top Heritage Dryers Experts
roeb
Michael Galve
Michael Galve
Mike
Are you a Heritage Dryer Expert? Answer questions, earn points and help others
