Question about Brother MFC-5440CN All-In-One InkJet Printer
Can't print documents from Word.
I can send documents from the Internet and print them, but I can't print any documents that are created in Word. My printer will print in color off of the Internet and so I changed my black ink cartridge tonight and it still will not print Word documents. All the settings appear to be correct. Help, please.
  • Anonymous Dec 03, 2007
    I can print in Works, and office excel but cannot print word 2003 or adobe documents. I have installed new print drivers and reinstalled both Office 2003 and adobe programs.
Maybe you can try copy and paste it. Well I hope it works!
Posted on Nov 04, 2007
  • 832 Answers
Did you do a test print by pressing ink testprint etc.? Do you have all colors incl. BK? If yes, check the printersetting WITHIN Word. Is the mfc the printer to be recognized by Word or is it another one? If you miss the bk upon the test sheet try to clean the ink cart by help of pressing ink arrow-down-button (cleaning) and (blue) start mono. If there is no or not enough ink check the cart. In case you use third party ones, use an original brother cart and do the cleaning twice. Third party carts do make a lot of trouble due to malconstruction!
Posted on Oct 10, 2007
Fax from computer
First, you will need a USB fax modem. Then you use Windows Fax & Scan program to create/forward new fax documents, or even send a file as a fax or email.
Setting up your external modem to work with an internet telephone line is simple. Simply put a 2 way splitter into the internet modem telephone jack. Plug your telephone into one input and the external fax modem into the other. Then you can even dial from your computer routine telephone calls too.
Need more explanation? Let me know.
Mar 14, 2014 | Brother MFC-7460DN
Is there a way to hook up my hp lazer jet pro m1212 nf mfp to be able to send a fax utiling my laptop which is by wifi. In other words no land line available.
Without a dial-up line available for your fax machine, the only other way to fax is via the internet if it's supported by your MFP. Google online faxing or fax via internet for solutions you may be able to use in your situation.
Fax or facsimile was invented as a way to take a printed document, scan it into digital form and transmit it to it's destination in a matter of seconds -vs- sending it via an expensive courier taking hours or days. This is before the internet, Adobe and other players made a way to create and send documents via the internet without the need for a fax machine and dedicated phone line. While faxes may still be sent that way when the printed document is the only media available, faxing has died off considerably. Most large companies now have ways implemented to move documents digitally without the need to fax. I predict the fax portion of a MFP to disappear in the not too distant future. Earlier MFP's didn't include a fax feature and one had to but the next model up to get it, now it's included in nearly every MFP. Adobe's PDF format with the ability to fill in the forms fields electronically (as in your US taxes) without having to have expensive office software made printing and faxing a thing of the past. Don't be surprised if the business or other entity requests you, and all of us, to submit a PDF document to their business email address rather than a fax.
Good luck with your quest!
Oct 15, 2013 | HP LaserJet Pro M1212nf MFP -...
Word 2010 doc will not print. Will print with Wordpad.
Microsoft support describes several things to try. After checking to see if any new blank document you create could print or not, the next possibility is to rename the normal.dotm file that may be necessary to resolve this problem.
Procedure to check:
"Microsoft Windows 7
  1. Quit Word.
  2. Click the Start button.
  3. In the Search Programs and Files box, type or Normal.dotm depending on your version of Word.
  4. For each occurrence of the or Normal.dotm template that you find, rename it Normal.old. To do this, follow these steps:
    1. Click Normal.
    2. On the File menu, click Rename.
    3. Type Normal.old, and then press ENTER.
You can now print new documents that are created from the new global (blank document) template ( However, existing documents that were created by means of your old file may not print. If this is the case, go to the "Print the problem document" section to resolve problems with these documents.
If you cannot print this new document, there may be a problem that prevents Word from printing. If this is the case, go to the "Print the problem document" section.
Determine if the problem documents were created from the same custom template You may still not be able to print particular Word documents. Examine the problem documents to determine if they were created from the same custom template. To determine which template created the problem document, follow these steps:
Word 2010
  1. Open a document that you cannot print.
  2. On the Developer tab, click Document Template in the Templates section.
  3. On the Templates tab, look in the Document template box."
Jan 12, 2018 | HP Office Equipment & Supplies
I have an HPPhotosmart C5280. I want to print on an evelope 8.2 x 5.5 for a wedding invitation. The printer tells me paper mismatch every time I try it. I set it up every time on the computer, it prints...
The easiest way to print an envelope is to use Microsoft Word. If you have the software installed, go to start and then create new office document and click blank document. When the document opens, click on help and type in envelope. This will give you instructions on how to create an envelope and save a copy to your document. When you save a copy to your document, it gives you a picture of an envelope which helps to create it. Then click on file, and slide down the print and click ok. Creating the envelope through Word helps to change the printers paper settings. Word will send a signal to the printer to tell it what type of paper and size of envelope you are creating.
Hope this helps?
Jul 18, 2011 | HP Photosmart C5280 Printer
HP C6100 all-in-one - won't print Word documents - only get a blank piece of paper. Will print documents from other programs, off the internet, etc.; just not anything that has been created in Word
I have found that if I save my document as a pdf that it will print. I am not sure why this has happened, but it didn't start until we upgraded to Word 2010.
Mar 28, 2011 | HP Photosmart C6100 All-In-One Printer
I just replace my printer cartridges and i trie to print off the internet. it did not print the text, but did print the ads on the side. so, i copy/pasted to word and then tried to print and it only...
Found this on the Web Site. If you find helpful, pls rate me. For Epson, You must use Genunie Ink Cartridges. A MUST........
You may be copying something that is "proprietary" . The owner may have it copyright . Owner who can exercise control over what users can do with the software, in contrast to public domain.
Found this on the Web Site, if you would like to copy using the print screen key.
The key may appear differently depending on the manufacturer of your Windows keyboard. The standard position would be at the upper right hand corner of your keyboard and may appear within this sequence of keys...
The sole function of this key is to take a snapshot or picture of your computer screen and copy it to the clipboard (the clipboard is an invisible holding area for content that is copied). Its the same thing as if you copied something from a document and it is now on your clipboard waiting to be pasted in its final destination. Its that simple. As quoted by Webopedia...
Often abbreviated Prt Scr, the Print Screen key is a useful key supported on most PCs. In DOS, pressing the Print Screen key causes the computer to send whatever images and text are currently on the display screen to the printer. Some graphics programs and Windows, use the Print Screen key to obtain Screen Captures.
Now, how do you get to see those Screen Captures or maybe even send them to someone? The quickest and most effective method is to have a graphics editing program handy. If that is not an option, you can open your favorite word processing program and create a new document. Position your cursor at the beginning of the document or wherever you want the screenshot to appear.
Using your keyboard, press Ctrl + V which will Paste the screenshot in your open document. Now you can Save (Ctrl + S) the document to wherever you wish, make sure to name it appropriately so you can easily find it.
You can now send this file to anyone via email, use it in a presentation, create your own little book of screenshots showing how to perform a specific task, etc. The possibilities are endless.
We use the Windows Print Screen Key regularly. You probably will too once you get the hang of it!
Thanks and Good Luck.
Jan 30, 2010 | Epson Stylus Photo RX500 Printer
First time scanning
To send copy of printed documents to others, follow the steps below.
1. use your scanner to scan your printed documents, save it to jpg format.
2. Use your email to send the pictures.
login to your email
compose or create the message
attached the images
Hope that helps.
Jan 06, 2009 | HP Scanjet 4400c Flatbed Scanner
Printing to Winfax Pro
Are you using a trial version of this software or a full version?Please let me know.
Sep 13, 2008 | Symantec WinFax Pro for PC
Brother MFC-5440CN All-In-One InkJet Printer Logo
79 people viewed this question
James Cagle
James Cagle
Jim Keysor
