Panasonic tbm2ax01801 the hdmi port is no longer working
Shuttle83
  • 1139 Answers
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Posted on Sep 24, 2007
welcomejee
  • 10594 Answers
SOURCE: Panasonic TH-42PX60U HDMI stopped working
Please unplug TV from AC outlet and replug it after 5 minutes then check HDMI port.
Posted on Nov 28, 2008
jose_v17
  • 227 Answers
SOURCE: No sound on DVR HDMI port, but does work on other HDMI port
Not all HDMI ports support Audio or they do but only one way Audio out or Audio In. If you have an optical connection you can try that.
Posted on Apr 04, 2010
SD Tech
  • 14553 Answers
SOURCE: Panasonic Viera TC-L37X1 hdmi not working
What do you have hooked up to the HDMI ports? Just a cable box?
Posted on Apr 02, 2012
jerry_kramer
  • 3904 Answers
SOURCE: HDMI 1 and HDMI 2 no longer work on my TV. What can I do to repair this?
Sounds like you have a bad input board and it is only time before you lose three. If it is under warranty get it in otherwise start tracking down the part. Most of these are a plug and play device once the tv is apart.
Posted on Oct 08, 2012
Viera TH-L39E5K. Why isn't HDMI connection working?
Try a different HDMI cable first into all ports. Try every HDMI cable you have. Then try a different component into TV HDMI ports. If you are using the receiver to switch inputs, try running HDMI cable straight into TV. HDMI is very finicky. Some cables won't work or stop working for no apparent reason.
Nov 02, 2015 | Panasonic Televison & Video
5 year old plasma panasonic tv 42 " hdmi port not longer working, How to fix
hi you could try firmware update try the panasonic website hope it helps
regards
shaun
Nov 23, 2013 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
Oct 07, 2012 | Panasonic Tc-p50g20 Viera G20 Series 50"...
Hdmi ports not working
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
5 Hdmi ports
Port one, cable box
port two, blue ray player
port three, Boxee box
port four, XBox 360
For example
Aug 07, 2012 | Hitachi 55HDT79 55 in. Plasma HDTV
Apr 02, 2012 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
Nov 28, 2008 | Panasonic TH-42PX60U Television
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
HDMI Signal gone
Aug 24, 2007 | Panasonic PT-52LCX65 44" HDTV
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
