Question about Fahrenheat (F2548) Electric Baseboard Heater
Recently purchased electric fireplace model GW-2078 tuned it on and it is making a old noise?
Electric fireplace or wood burning fireplace. Which is better ?
Source: The Good And Bad Of Electric Fireplaces
You are able to save money by using electric fireplaces because they are significantly cheaper and more efficient to run. As opposed to turning on the heat for the entire home, you only have to actively heat one area although this is the same case for traditional fireplaces. Still, using an electric fireplace eliminates the need for buying wood, starting and maintaining a flame, and cleaning/servicing a fireplace with a chimney. Moreover, you are able to use an electric fireplace for an extended period of time. Wood-burning stoves are limited by the supply of wood. Gas burning fireplaces don't have that restriction, but require costly installment and creation of gas-line access. A foundational benefit of electric fireplaces is not causing any harmful particle emissions, which are a major side-product of traditional fireplaces, and one of the causes of their degradation.
How To Care For An Electric Fireplace
electric-fireplace-luqhqtew4twq4g4srgxhyj11-3-0.jpg Given the clear advantages that electric fireplaces have over traditional fireplaces, even die-hard fireplace lovers can justify making the switch to electric. Still, it is important to be apprised of the precautions and maintenance requirements before committing to a purchase. The most likely "repair" will be to change out bulbs as they die, typically about every two years. Models with LED bulbs will likely never need replacement. If you have a fireplace with conventional bulbs, replacing them is simple and straightforward. It is done by unplugging the fireplace, allowing it to completely cool if it was in use, and then accessing the rear panel of the unit. The panel can be unscrewed easily with a screwdriver. With the back panel removed, you should look for the bulb housing. This may differ from model to model, so consult the user guide before continuing (making sure to note what type of bulb is required). When you have the replacement, remove the old, and replace it with the new bulb. Some fireplaces require halogen bulbs which should not be handled by hand as this could compromise the longevity and quality of the bulb, in which case you should wear gloves to handle the bulb. With the new bulb in, you can screw back the rear panela and use the fireplace normally.
Electric fireplaces contain fans that are instrumental in providing heat to the room. The fan, as well as the other components, are usually pre-lubricated. However, if the fan is halting or not moving smoothly, it may indicate that cleaning is required. As with any other maintenance, make sure the unit is turned off and unplugged. You can use your vacuum's brush and wand attachments to clean the fan. Begin by taking off the grate and lightly cleaning to remove dust and grime. When finished, you can retrace with the wand attachment to pick up any remaining dirt. Replace the grate when you're finished.
The exterior mantle requires nothing more than occasional dusting and wiping. You should avoid the use of harsh chemical sprays, and instead, opt for mild soapy water and a lint-free cloth. Cleaning the glass display and mantle will make a big difference in the appearance of the unit. Be sure to dry the unit completely to avoid streaks and water marks.
Jun 21, 2017 | Home
Where can I get the remote for fireplace model GW- 2078
Walmart sells smart remote that control more than video electronic
Mar 28, 2016 | Heating & Cooling
Purchased a great world model swe071 electric fireplace. How do you control the feature to make the flame colors change automatically without using the remote every few minutes. Lost manual
I bought a great world ltd swe067b electric fireplace ... - Fixya
www.fixya.com/.../t25420081-bought_great_world_ltd_swe067b_electri...
Feb 12, 2015 - i bought a great world ltd swe067b electric fireplace a couple of months ago.it wont ... Purchased a great world model swe071 electric fireplace. Howdo you control the feature to make the flame colors change automatically ..
Oct 25, 2015 | World Heating & Cooling
GW-2078, makes a high pitch noise when fan is running, how can this be corrected, other than that it works fine
Without me physically hearing the noise I can't be certain but it sounds like a bad bearing from what you described. I would try spraying a little WD-40 or some type of lube. If that doesn't work then the fan motor may have to be replaced.
Jan 03, 2015 | Cars & Trucks
Noisy fan on electric fireplace
My recommendation would be to contact a fireplace showroom that sells electric fireplaces. It would be best if you could inspect your fireplace for the sticker that identifies the fireplace's brand and model#. The primary concern is contacting a showroom that is able to order parts for that brand...
Mar 17, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Model GW-2078 has stop working will not turn on
Its probably a safety switch has tripped on the inside
Nov 01, 2012 | Heating & Cooling
I need a remote for my Great World LTD GW2078 electric fireplace
I would first Google the model number with "remote" to see if you can locate one on the internet.
Oct 31, 2012 | Radio Communications
FEBO fireplace, GW2078 anyone have a website or number????
Not a solution, but a problem. I bought a 2078 from Big Lots 2mo. ago. Friday night, nothing. Checked plugin breakers, etc. Finally disaasmblrd the entire thing and checked every led,circuit, etc, and found nothing out of place or burnt. Now What? Taking it back to Big Lots today in a million pieces. Hope they can take a joke. Really like the outfit but need it to work.
Sep 19, 2011 | Heating & Cooling
Fahrenheat (F2548) Electric Baseboard Heater Logo
46 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
paulcarew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
