Question about Philips 50PFL3807 - 50"" Class 49.6 viewable LCD TV
My philips 50pfl3807/f7 wont stay on
Cant get to the menu because it goes to a black screen and no response from volume, menu, nothing works.
2 Suggested Answers
  • 579 Answers
SOURCE: Philips 46PP9302 46 in. Rear projection -
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Posted on Jan 22, 2008
My philips 47pfl5603d/f7 wont turn on, it stays completely black
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 27, 2015 | Philips 47PFL5603D/F7 LCD HDTV, 47...
47" philips lcd tv goes black but still has sound
Yeah the picture tube is old.... if it's a lcd or led then u're having prob's with display Circuits... call a techie and he'll fix it
Jan 11, 2014 | Philips 47PFL3603D/F7 LCD HDTV, 47...
Sound on Philips Smart TV 50PFL3807 stopped working
check the cables or take it in to get it checked
Oct 12, 2013 | Philips 50PFL3807/F7
Unsupported usb
can you tell me the model of your external Hard drive and the model of your system so that we have more information about the issue that you are having..
Thanks
EJ
Jul 13, 2013 | Philips 3000 series LCD TV 50PFL3807 50...
New Philips Televion dim and flickers
You should return the player because if it is dim and flickering than there is a miss connection in the play. It could also be that your tv is not compatable with that player.
Dec 25, 2012 | Philips 50PFL3807/F7
Flashing
If this is an LCD TV, the backlight is failing
Sep 28, 2012 | Philips 50PFL3807/F7
When I plu-in the VGA cable my screen goes blank on my HP-1170. I then have to reboot to fix video on laptop. Done all the resolutions and I cant seem to get the external projector to show anything other...
reset the settings to factory default through the menu. swap out the cable. depending on your laptop, press function-f4 or function-f7. if still nothing, you may have a main board issue.
Dec 27, 2009 | 3M MPro110 Micro Professional Digital...
GV42L Vizio HDTV Problem
You didn't mention whether you have any audio; details like that can influence the response.
If you have audio but no visible video, look at the screen from an angle for 10-20 seconds to see if any video is present. If you do see some shifting shadows on the screen and have audio, the backlight or its power supply (inverter) has probably failed.
Nov 19, 2008 | Vizio GV42L 42 in. LCD Television
My philips mp3 wont work
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Jun 02, 2007 | Philips HDD1630 MP3 Player
Philips 50PFL3807 - 50"" Class 49.6 viewable LCD TV Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
