Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Mitsubishi mr slim I want to control with z wave technology is it possible?
  • 6 Answers
SOURCE: no heating from Mr slim
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
regards
Ed
Posted on Nov 14, 2007
22yooper
  • 828 Answers
SOURCE: Mitsubishi Mr. Slim M/N MSH15EN
Try calling G A Larson's for technical advice. I think that they handle this product. 499-0866
Posted on May 22, 2008
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
louislevel_2
  • 374 Answers
SOURCE: air conditioning unit leaks
hi there,
there no other way to repair that leaks other than you call an ac technician from service center and they will find it to you because there are special leak detector they will use to find where that leaks was and they work it using oxy acetylene welding to patched that leak,after patching they take a leak testing using high pressure equiptment to leaks test the system.so they can charge free from leaks,leaks should be stop because to protect our ozone layer.regards
Posted on Jul 05, 2009
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
The remote control for a Mitsubishi Mr. Slim unit was lost. How do I find a replacement? What info do I need to find the correct controller? Thanks
Mike you can find an OEM replacement a the following link. To get the right one, you will need the model # of the one you lost. If you don't have that, you acn call or email the company for assistance.
http://remotecontrols.com/index.php/mitsubishi
I hope this helps you and thanks for choosing FixYa.
Sep 19, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
May 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
How do your read the serial# of a MUY-A24NA unit ,
hi.right below the model number there is a number that has numbers...model is muy-a24na..this is a 2ton unit...serial is possible the other number...hope this helps you..michael doctor airr appl.repair...843-384-8474...call if need some advice...its free..good luck
Mar 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Mitsubishi Mr Slim model MSZ12UN. The
you must see the indoor fan and you must clean it very good as well all the indoor unit.
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Apr 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
64 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
