Question about Fujitsu Siemens LifeBook S2210 Laptop AC Adapter, 16V-4A (AC28VPNKXJPR8)
How to dismantle
Fan is giving a lot of weird noises. Tried looking for manual guide to open up the laptop but could not find one. Please help
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 173 Answers
Google for "service manual s2210" filetype:pdf.
Posted on Nov 24, 2013
Service Engine Soon light
First get a scanner to check the code then you will see what happen.Go to auto zone they will check.
May 05, 2013 | 2002 Saturn L-Series
My hp pavilion dv4 laptop fan starts then stops constantly and makes weird noise
you attached the fan usb 5 volts supply .your laptop fan are constent lee rotate
Jun 06, 2012 | Computers & Internet
Weird noises coming from the bottom part of the laptop
ovitzroei, Ram Memory modules do not make noise.
No moving parts,
Average SO-DIMM ram memory module as used in a laptop,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
The bottom has gold plated contact pins.
The black rectangles are DRAM chips.
They are mounted on a Printed Circuit Board.
The CPU also has no moving parts. (Central Processing Unit. Another name is Microprocessor, or simply Processor for short )
Although I have heard stories of CPU's going out, and playing a song remnant of 'Taps', or Brahms 'Lullaby'.
The harddrive used in your laptop is mechanical, with moving parts.
Information,
http://computer.howstuffworks.com/hard-disk.htm
http://www.youtube.com/watch?v=t6wTZhsffEE
Yes, possible it is/WAS the noise.
Methinks the Fan Assembly should be checked out,
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=4247575
Service and maintenance information > HP Pavilion dv3 Entertainment PC - Maintenance and Service Guide
[ Service manual ]
Unless it's still under warranty. Then you just send it in again, and may want to be a little more AGGRESSIVE this time.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 05, 2012 | HP Pavilion Computers & Internet
My laptop fan is noising
Use a can of compressed air, blow out the open ports including the fan, may help, chances are the laptop will need to be dismantled down to the motherboard level to do a proper clean out, the cooling fan will probably need to be replaced in order to get things working properly.
Apr 13, 2012 | Computers & Internet
Fan noise solving method
The fan is reaching end of life, or there is a lot of dirt build up in the cooling fan and the heatsink ports. The ideal way is to dismantle the laptop down to the motherboard, remove fan and heatsink use a can of compressed air blow all dirt from open ports and the cooling fan, and in most cases it will run better
Apr 03, 2012 | Sony VAIO(R) VPCF133FX/B 16.4" Notebook PC...
My computer fan is making noise and needs to be replaced
Follow this through, it may be over kill but at least it has pictures for you so you know what to expect getting into the fan
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A85/replace-laptop-memory-2.htm
Feb 11, 2010 | Toshiba Satellite A85-S107 Notebook
Therea are a lot of noise becouse the ventilator. El ventilador hace mucho ruido y se calienta,
If you have a Dell Latitude 410,(I didn't see it in your post , but it was at the top of the column) I found a user manual here: http://support.dell.com/support/edocs/systems/latd410/en/ug/index.htm But I believe from the looks of your post that might be Spanish, guia de usario: http://support.dell.com/support/edocs/systems/latd410/sp/index.htm The user guide said the fan only comes on when it needs to and some fan noise is normal. Laptops can get hot after extended use. Just be sure to give it plenty of room by the vents and make sure nothing becomes lodged in them. Dust bunnies, dirt and animal hair are known to cause problems. If you need to replace a part, check with Dell about your warranty.I hope this helps, and good luck. If I 'fixed ya' please rate me. Thanks.- jmattes
Oct 24, 2009 | Dell Latitude D410 Notebook
Unexpected shut down
First, you need to find out what is causing the shutdown problem.
Most likely since you have this laptop for 3years now and (i am assuming you havent had this serviced). You might be suffering from overheat problems since you are using a DESKTOP P4 cpu.
Try to dismantle your laptop and remove the Fan and Heat sink. CLEAN them and put new thermal paste to the cpu.
Do that and see if this fixes the problem. If not, let me know again
If i was able to help please rate this solution as a fixya!
thanks
Apr 11, 2008 | Toshiba Satellite A75-S231 Notebook
Fujitsu Siemens LifeBook S2210 Laptop AC Adapter, 16V-4A (AC28VPNKXJPR8) Logo
64 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
