Question about Visonik V117SX Car Audio Amplifier
Ok the amp is all hooked up but the power light wont come on but the PROT light comes on...so i have no idea how to get the amp to work to test the sub? And the rca cables what do they hook up to?
    Problem Solver:
  • 5 Answers
The RCA cables are for leads from your deck to your amp. Assuming you have an aftermarket deck, pull it out of the dash and look at the back. There should be a red out put and a white output for your cables to plug into. They're sometimes labeled left and right to help you make sure you hook up the amp right. If not, just be sure to match them up between the deck and the amp. If you have the stock deck in there, it's unlikely that you'll have RCA outputs, as most stock decks I've seen do not. As for the protection light being on, your amp is most likely shorting to ground somewhere. Be sure you don't have it screwed right to any metal parts of the car, as this can cause problems. Most amps have a section in the manual warning against this and the problems it can cause. Some amp manufacturers don't say anything about that or say that it will be safe, but, as a rule, I always just play it safe and mount it either to my sub box or on a piece of plywood or something that is secured in the car. Also, make sure that the in-line fuse on your power lead isn't blown, and most amps have one or more fuses on the side of them, so check those, too. If none of these things are wrong, then it might be an internal problem and I can't really help you with technical stuff. Hope this helps. Please leave feedback, too.
Posted on Oct 10, 2007
Nothing will come on
have you wired it back in correctly? and have you connected the auto ariel lead back to the remote connection on your amp?
Mar 17, 2010 | Visonik V117SX Car Audio Amplifier
WHY DOES MY AMP CONTINUE TO BLOW ITS FUSE ..I HAVE A 4GA AMP KIT ON IT ......IS THAT TO BIG ..I DONT EVEN HAVE ANY SUBS HOOKED TO IT ..VISONIK V107SX
go with an 8GA wire and see what that does for you because the battery is sending power to an amp but the amp cannot transfer all of that power anywhere without speakers being ran to it if you think 8GA is to small then try running a fuse in with your 4GA
Jun 23, 2009 | Visonik V117SX Car Audio Amplifier
Visonik 350watt Amp Doesnt Come On....
With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Oct 06, 2008 | Visonik V117SX Car Audio Amplifier
Amp problems
The head unit probably has 2 control wires. One has 12v when the signal source is the tuner. When you switch to the other sources, the antenna is not needed so the output to that wire is switched off (so the power antenna will go down).
Look for a wire marked amp control or something similar. It will have 12v output any time the head unit is on. Use that one to control your amplifiers.
Apr 04, 2008 | Visonik V117SX Car Audio Amplifier
My amp is not working
For the visonik, you should check your speakers. You can use a D-cell battery. Remove the speaker wires from the amp and connect each speaker across the battery (for no longer than a few seconds). The speaker should pop each time the wires are touched to the battery. If they don't, the speaker is defective (assuming the battery isn't dead).
If the speakers are OK, you need to confirm that you have a good signal feeding the amp. You can use the RCA cables from another working amp in the vehicle. Do this with the amp that had the power light lit.
If you have signal going to the amp and the speakers are OK, the only two things left are the power supply feeding the amp (from the battery) and the amp. If you have B+ and remote voltage AND a good ground, the amp is defective.
For the pyramid, the amplifier probably has shorted output transistors. The amplifier will have to be repaired.
Nov 16, 2007 | Visonik V117SX Car Audio Amplifier
Visonik V117SX Car Audio Amplifier Logo
166 people viewed this question
Top Visonik Car Audio & Video Experts
Joe Alexander
Joe Alexander
ELECTRICKS
ELECTRICKS
Jesse Cofske
Jesse Cofske
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
