Question about Brother Sewing Machines
Adjusting my pr1000e tension
How do I make sure I'm adjusting my tension correctly on my brother PR1000e? I've tried what was recommended in the manual but now it seems worse than before.
SOURCE: Brother Industrial Machine Tension
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Posted on Nov 30, 2008
redbeard00
  • 957 Answers
SOURCE: Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Posted on Apr 26, 2009
bargainbox
  • 1388 Answers
SOURCE: Husqvarna Lily 530- dont know how to correct tension
Ask your local Husky dealer about availability of manuals.....if no joy, google "Husqvarna Lily 530 manual"
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 23, 2009
  • 980 Answers
SOURCE: I have a brother XL-2600, I have used many sewing
Sounds like you have tried everything possible, be sure you are using an anti static needle on the delicate fabrics, if that does not work it really does mean fiddling with the tensions until you get it dead right
Posted on Nov 06, 2009
SOURCE: I have an ancient Brother VX -1200 sewing machine
checked the to see if then needle is bent-thread loops on the bottom could be caused by 2 things--a blunt needle or tension, check needle first--if it is even slightly rough or blunt at the tip change it.
is the needle in backwards
Posted on Jul 30, 2010
My Brother Dream Machine has the bobbin thread showing on all embroidery work. How do I adjust?
try adjusting the needle thread tension up a bit
practice on scrap material until the tension is right
May 03, 2017 | Brother Sewing Machines
Tension problem. bottom thread loopy.
Make sure the bobbin is the correct one for the machine first. Try another bobbin on a scrap of material. Bobbin will fit into the bobbin holder going the incorrect way. Make sure the thread is unwinding in the correct direction. mine has a arrow for the correct position. Hope this helps.
Aug 21, 2014 | Brother XL2600I Free Arm Sewing Machine -...
The thread is birdnestting where the bobbin is
Birdnesting can be corrected by adjusting the bobbin tension lower. You need to check for threads stuck in the bobbin tension and clean them out. The thread should feed out of the bobbin tension with a small amount of tension. Make sure your bobbin is rotating the right direction; probably counter clockwise. Adjust the top to three and give it a try. You may need to make a small adjustment on the top tension. Your goal is to have the bottom and top tension equal just like a tug of war.
Jan 22, 2014 | Brother PE-500 Embroidery Machine
How can I adjust the timing on a brother ls 1217 sewing machine
Unfortunately, it's not recommended for users to repair their own brother machines. It sounds like the timing is out anyway... to take it in and have it "Cleaned, Lubed, timed and the Tension repaired"
Or you could use it for target practice and just go buy another machine.
Dec 12, 2012 | Brother LS-1217 Mechanical Sewing Machine
I can't form any stitch on my brother 3d - they are all loose and long and uneven. Do you know how to fix this please?
try changing the needle
try adjusting the top thread tension to 3 or 4
rethread the machine top & bobbin
make sure the bobbin is inserted correctly
& also wound correctly
Aug 05, 2012 | Brother Sewing Machines
Thread tension
try changing the needle first--make sure the needle is the correct one for the fabric being sewed.
if you've adjusted the top tension & the bottom stitch still looks the same
it's possible that the top tension dial is needing to be checked to see if it's
working correctly
Apr 17, 2012 | Brother CE4000 Computerized Sewing Machine
Tension of pe770
Besides the other advice here, check your bobbin case. At first I didn't get my thread hooked into the bobbin case properly and had problems that looked like the bobbin tension was not adjusted properly. I have to take the case out, put in the bobbin to make sure it's caught properly and then put it back into the machine. This is what worked for me.
Mar 14, 2012 | Brother PE770 Computerized Sewing Machine
I have a brother XL2600i machine. It was sewing fine, but now, the bottom thread is all loopy. I have tried reinserting the bobbin, and making sure that it goes through the tension adjusting spring. But it...
try these suggestions
check top tension & try a tension of 3 to 5
try a new needle-flat side goes to the back of machine--also make sure the needle is the correct one for the fabric & thread
Sep 09, 2011 | Sewing Machines
My seams are puckering. I have a Brother sewing machine. What am I doing wrong?
Puckered seams are usually caused by incorrect tension. But first check to make sure your bobbin is inserted correctly and that there is a good tight wind on the bobbin itself. Then, check the tension disks in the upper threading and make sure there is no stray thread lodged in there. Next, check the upper threading to be sure you have the thread going correctly through each of the thread guides and between the tension disks/plates. Finally, check the tension. Generally it should be on 3 but each machine has different symbols for the tension. My Brother product uses a 3 tension. I've been sewing for over 50 years and I still occasionally have pucker problems. It's usually because there's a small stray piece of thread in between the tension disks. I hope this helps you. If it does, please come back to Fixya and rate my information! Thanks.
Aug 02, 2011 | Sewing Machines
Nov 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
87 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
