Dell inspirion n5030 laptop
Arrow pointer will not move (frozen)
    Champion:
    New Friend:
  • 206 Answers
Are you using the touchpad, or a regular mouse plugged into the laptop. If you are using the touchpad on the laptop, make sure it is enabled. There is a button to the right of the F12 key to enable/disable the touchpad. If you are using an external mouse connected to the laptop, try restarting the computer by pressing the power button once (that will initiate a shut down).
Posted on Jul 15, 2014
harvester3
  • 181 Answers
SOURCE: Dell laptop pointer problem
This is a very common problem for most Dells this age.
You can try this repair if you feel comfortable.
Remove the keyboard by removing the power button bar (just gently pry up from the right side working left)
re-insert the mouse cable which is coming from the pad/palm rest. Re-assemble.
Check if all the screws on bottom of the unit are tight, especially around the palm rest area.
Good luck
Posted on Nov 06, 2007
  • 909 Answers
SOURCE: the arrow is frozen on my laptop other than that the pc is working normally
Could be the mouse lock key. I am unsure as to which key it is on yours. Mine is the F9 key. it will have a picture of 2 mouse on , 1 with a no go sign over it (circle with a diagonal line through) try pressing the "fn" key and F9 and see if this unlocks the cursor.
Posted on May 23, 2009
  • 59 Answers
SOURCE: Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Posted on Jan 04, 2010
SOURCE: Dell Inspirion 1521 Laptop Microphone Wont Work
I have a Dell Inspirion 1521 same mic issue.....so it was corrected driver R167846
Title: Audio: SIGMATEL STAC 92XX C-Major HD Audio Driver
Version : A02
OEM name : SIGMATEL
OEM Version: 6.10.0.5609
Computers : Inspiron: 1420, 1520, 1521, 1720, 1721; Vostro Notebook: 1400, 1500, 1700; XPS: M1330, M1730
OSes : Windows Vista 32-bit Business,Windows Vista 32-bit Home Basic,Windows Vista 32-bit Home Premium,Windows Vista 32-bit Ultimate,Windows Vista 64-bit Business,Windows Vista 64-bit Home Basic,Windows Vista 64-bit Home Premium,Windows Vista 64-bit Ultimate
Languages : Brazilian Portuguese, Chinese-S, Chinese-T, English, French, German, Japanese, Korean, Spanish
Created : Wednesday, November 07, 2007
Posted on Feb 27, 2010
  • 60 Answers
SOURCE: ppo1l dell latitude laptop mouse
is this a laser type mouse or a touchscreen type in the laptop?
Posted on Mar 12, 2011
How to unlock a frozen pointer
try going into your control panel and click on the pointer icon and see if you can set from there
May 19, 2014 | ASUS K Computers & Internet
Arrow wont move with built in pad
Try to unistall and re install the touchpad drivers.
Nov 23, 2013 | Dell Inspiron N5030
My Cursor pointer is frozen. The arrow is frozen but if I move the mouse and it blindly finds a tab and I click it that works but no movement of the arrow until I reboot
Does it happen on a specific application or all over your screen? Are you using a special mouse/tracking ball/pointing device? Is this a laptop or a desktop? if you use a USB "simple" mouse does it work. Seems to me like a driver problem.
May 15, 2011 | Computers & Internet
How to adjust mouse sensor pad. I have a Dell Inc., 1501 inspirion lap top. .x86-based pc. I need to know how to adjust the sensitivity level on the mouse sensor pad (if that is what's its called). it...
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you will have the options to troubleshoot also select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
you might have to uninstall the drivers restart your computer then reinstall the drivers
in xp
hope this helps
Jan 18, 2011 | Dell Computers & Internet
Dell inspiron n5030 xp drivers
hello
i want drivers of dell inspire n5030 wireless drivers for the xp
Oct 20, 2010 | Dell Computers & Internet
I have dell 110L inspirion with XP professional.
I think your Windows installation is damaged. Boot from your operating system CD. (Go into setup mode F2 or delete during bootup. Go to the Boot select screen and set up to boot from CD. Place your OS CD in the drive and power on.) When it boots, it should give you the option of REPAIR. Select this and allow Windows to repair itself. I hope this helps you resolve your problem.
Nov 16, 2009 | Toshiba Portege M700-S7044X Notebook
In touch sensitive mouse in Dell 6000, I have problem
Move the mouse pointer to the right down or up arrow at the right bottom or top of the screen and press the button.
Hope this helps.
Good Luck.
Jan 04, 2009 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
David Payne
David Payne
