Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley Davidson ACR problem
ACR'S activate when standing bike upright from side stand or when you push the trip button or push the run/start button. Also, if you pull out the main fuse and reinsert it, they will also activate. Can you help?
SOURCE: Trying to install a harley davidson tach on 2007
The pink wire goes to the pink eng rpm signal wire coming from the ecm. Go to the stealership and ask 'em to show you where it is.
Aloha
Posted on May 01, 2009
SOURCE: 2006 Harley Davidson- No tach, speedo, blinkers
ckeck your fuse block
Posted on May 04, 2009
OneRide
  • 379 Answers
SOURCE: harley davidson evo motor wont turn over...just clicks
Pull the spark plugs out and hit the starter. This will make sure that the engine is not locked up. If the starter does not turn the engine, put the bike in first gear and have someone push you, making sure the engine is free. If the engine is OK, your starter is probably jammed and needs replaced. That wire getting hot is a dead giveaway something is locked up tight...starter or engine. If ya have a large hi-performance engine in the bike, chances are your stock starter won't do the job.
Posted on Jun 26, 2009
REDOIL
  • 355 Answers
SOURCE: having trouble changing a kick stand spring on my
well the easy way is to jack up bike remove the nut jiffy stand slide it out hook spring slide it back in and tight nut hope this helps
Posted on Sep 30, 2009
  • 221 Answers
SOURCE: Harley won't start.
A harley AGM battery are usaully good for three to five years the best thing to do is have the battery load tested.Now as far as your problem now depending on the batterys state of charge the solenoid will click or not.Because you store it alot you should keep a trickle charger on the battery
Posted on Apr 11, 2010
Testimonial: "Thanks for the advice, gives me a direction to pursue. Will have battery tested and hopefully that is all it is."
I washed my 2012 softail slim went to start it all the lights came on except the neutral light and the dam thing won't start and yes the bike is in neutral I push the start button and get nothing
Hi, Michael electrical components do not like water check your fuses and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below, and for specific information or questions please feel free to contact me at xlch@mail.com Good luck and have nice a day.
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
BIke won start Acts like dead battery but it isn
Harley Davidson Softail Won Start
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Apr 17, 2016 | DAM Motorcycles
Flstf 92 will only start if i am seated and the bike is upright
Hi Marty, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
If you are still having problems contact me at: xlch@mail.com
Good luck
May 25, 2015 | Harley Davidson FLSTF - FLSTFI Fat Boy...
Harley trouble codes
Your side stand (jiffy stand) safety switch has broken or got the wires to it damaged. It is mounted at the top of the jiffy stand by a single 1/4 bolt.
Jul 08, 2014 | 2011 Harley Davidson XL 1200N Nightster
Do u check trany on side stand r upright on 2001 dyna wide glide
Check the oil level in the transmission with the bike standing as straight up as safely possible. Don't let it fall over. The oil level should be between the two marks on the dipstick. Your transmission holds 20-24 ounces of oil. Check the engine oil with the bike on the sidestand and keep the oil level between the two marks on the stick. Avoid "topping off" the oil tank. As long as the level is between the two lines, it's fine.
Steve
Jul 26, 2011 | 2001 Harley Davidson FXDWG Dyna Wide Glide
Do you check the gear box oil level when the bike is on the stand or up right
Always upright, if it is checked on the stand then it may give a false reading, and you may over or under fill the gearbox. Manufacturers state this as they can not control the angle of what you stand the bike against, but all bikes will be the same when standing.
Jan 24, 2011 | 2000 Harley Davidson FXDWG Dyna Wide Glide
While egine hot or cold, bike position, should the dip stick be screw all the way in or not?
check oil hot, and as far as if it should be on kick stand or not can easily be determined by the dipstick, the rule is if the dipstick moves from side to side then check it on the kick stand, if the dipstick is solid then check it upright. the dipstick should always be screwed all the way in and then take it out to check fluid level. I hope this helps you.
Nov 10, 2010 | Harley Davidson FLHX Street Glide...
Oil capacity
standing upright,
after a short ride. let it rest 30 seconds in standing position before to check.
Apr 23, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Harley davidson flstc heritage softail 1997
The fork oil is a very specific job needing a manual and a special tool, I don't want to insult anyones mechanical knowledge but if you have never done it before, best to take somewhere else. Engine oil on the other hand is easy, the drain tube to any softail is on the right side by where the frame meets the swing arm, has somekind of plug in it. Start and run bike for a little while, long enough to get it warm but not hot. Remove fill plug and then remove plug in drain line. Using a peice of cardboard or something put in between filter and frame , directing the oil to your drain pan instead of where ever it goes. Put 1 qt oil back in (after everything is reinstalled) start the bike and make sure the oil light goes out, when it does shut bike off and fill to the point that when it is standing upright you get a little oil on the tip of your finger, over filling may result in loss of oil cap from pressure (been there)
Jun 15, 2009 | Harley Davidson FLSTC Heritage Classic...
Center stand
1. Start with the bike on its side stand; 2. Grip left handlebar with left hand; 3. Grip frame member with right hand; 4. Place foot on center stand lever; 5. Pushing down on center stand, tilt bike till both legs of center stand touch ground; 6. Push down hard with foot and lift/pull on frame member.
Nov 20, 2008 | 2008 Harley Davidson VRSCAW 105th...
Lands Phones Logo
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
