Question about Covercraft Block-It 200 Custom-Fit Car Cover for a Ford Mustang
2007 Mustang GT/CS heat/ac motor only works on low. Checked the fuses (under dash and under hood), all good, changed the resistor, finally bought a new motor...still only works on low speed. Is there something I might have missed? Is there an easy way to check the switch itself? Please help....it's winter and I'd like to not drive while suffering hypothermia!
  • 794 Answers
Use an ohm meter to check the switch.
http://www.allaboutcircuits.com/vol_6/chpt_2/2.html
Posted on Nov 24, 2013
No Rear air. A/C and heat do not work in rear.
ligh illuminator and switch are different circuts, check for power both sides.
Apr 24, 2014 | Honda 2004 Pilot EX-L 4WD
Ac fuse location
not sure where the fuse is for sure either under hood or drivers side under dash,but if the refrigerant gets low as it will over time or if theres a leak the ac clutch will not kick in. even with heat on defrost the ac clutch should kick in and out if ts working proper
Feb 17, 2014 | Dodge Nitro Cars & Trucks
Interior blower doesn't work for heat, defrost,ac. Checked fuses
not sure what vehicle but either the blower motor is bad, the resistor is bad and its located usually on the firewall or inside under dash passenger side.. check relay tooo...
Dec 10, 2010 | Dodge Dakota Cars & Trucks
AC BLOWER NOT BLOWING
The resistor that controls the blower motor. it is a small gadget that has a 2 or 3 wire plug . Replacing the resistor should fix your problem. It is on or near the blower motor. Under the dash. Not easy to remove . But it can be. Please give thumbs up if helped.
Jan 21, 2010 | 2007 Jaguar XJ8L Sedan
No heat
Have you checked the relay for the system. Should be in the under hood fuse block.
Oct 07, 2009 | 2004 Dodge Dakota
Blower on the heater/AC not working on 1998 Escort, checked fuse under dash?
Ok, first off, check the fuses under the dash. If they're all good, does the blower work only on high speed? If yes, then you have a bad blower motor resistor, which is located under the hood, near the blower motor itself. If the motor doesnt work at all at any fan speed, make sure the wiring harness that plugs into the motor under the hood is clean and tightly installed. If it still doesnt operate, sometimes tapping on the blower motor housing will kick it on, but if that doesnt work, you may have to replace the blower motor. They are available aftermarket, and arent usually too expensive.
May 24, 2009 | 1998 Ford Escort
89 Honda Accord Heater doesn't blow air at all
sounds like the blower motor, Get a test light and hook it up to the wires going to the motor this will tell you if power is getting to the motor . Hopfully it is , Just pull the panel off on the pasangers side under the dash and you can see the motor . It's easy to change and should fix the problem. If you get no power it check for power at the switch on the dash . It could have gone bad !!
Feb 03, 2009 | 1989 Honda Accord 4 Door
1976 cadillac deville ac/heating problem
check the resistor block; this resistor block controls the ground side of the fan motor, some caddys used a digtal display and on those the power relay also control power if was normaly found under the hood next to the wiper module some were under the dash.
Jun 29, 2008 | 1976 Cadillac Deville
Covercraft Block-It 200 Custom-Fit Car Cover for a Ford Mustang Logo
Top Driving Comfort Vehicle Parts & Accessories Experts
Robert Plante
Richard Warren
Richard Warren
jose
jose
Level 1 Expert
Are you a Driving Comfort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
