Question about Zyxel P660HW-D1 Router
Router cannot connect to belkin g usb adapter it worked fine yesterday and today nothing!
Hello, I have a Zyxel router mod P660HW-D1 and a Belkin G USB adapter...how do I get them to connect up via wireless...
    Genius:
  • 1,269 Answers
Make sure to install the USB adapter's driver and utility. If it's installed, you need to use the Belkin WLAN Utility to connect to the wireless network. You should be able to find the signla coming the router and you can connect to it
Posted on May 07, 2009
SOURCE:
Need to buy a replacement power adapter for this model, can you tell me what the dc output and connector size is - Zyxel P660HW-D1
Dc output is 12v and 1amp.
You can buy power adapter for Zyxel P660HW-D1 from nearest computer shop or from internet.
It's power adapter needs 12v and 1 amp.
Let me know if you need further assistance.Thanks for using FixYa.
Jun 13, 2010 | Zyxel P660HW-D1 Router
How do i make the security settings?
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jan 02, 2010 | Zyxel P660HW-D1 Router
How to change nat settings for a belkin n wireless router
you will need to change some settings on the router.
reduce the MTU. if the MTU settings on the router id 1500 then change 1365.
also you will need to open some ports on the router.
Click Here for more info
Dec 12, 2009 | Zyxel P660HW-D1 Router
How do i change my nat setting from moderate to open?i have a belkin g 54 router number fsd7231-4
I think you want the NAT open for X-box.
For this you need to open the router set up page.
Is there any computer connected to the router .
If not then you will need to connect the computer to the router.
Reduce the MTU settings to 1365
open the ports for the router.
Nov 27, 2009 | Zyxel P660HW-D1 Router
No tengo el usuario ni el pass del router para abrir puertos
Hola Angela,
si eres abonada de Telefónica es fácil accediendo a la siguiente dirección: www.telefonicaonline.com/portalalejandra.
Simplemente te pedirá el Nº de teléfono. Ahí podrás configurar tus puertos, contraseñas, correo, etc.
Espero que te sirva la solución.
Un saludo,
FRANK
Para cualquier duda: francisco.cota@telefonica.net
Sep 21, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Problem
my modem and router were working well, and then my router has stopped working
Aug 16, 2008 | Zyxel P660HW-D1 Router
P660HW DSl problem
What do you mean to "remain solid"?
What model of your router and your ethernet adapter model?
Do you use wireless networking?
Feb 23, 2008 | Zyxel P660HW-D1 Router
Strict NAT setting on XBOX 360
my zyxel keeps losing internet conshone
Jan 09, 2008 | Zyxel P660HW-D1 Router
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
ZyXEL Wireless set up.
First many current PC models have switches to power on the wireless feature. Do you have one of those and did you power on the wireless.
Second wireless devices communicate on four different bands A, B, G, N. Some devices support multiple bands. Does your wireless router/access point (maybe a Zytel p660HW-D1 from above) support at least one of same bands as your laptop built-in or purchased wireless adapter? If you do not know post the manufacturer of the wireless router/access point, laptop if the wireless is built-in or wireless adapter if it is a separate device and I will check that for you.
Dec 26, 2007 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Logo
338 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Joaquim Martins
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
