Question about Canon PIXMA Office Equipment & Supplies
Canon 8500 error code E0069
Canon copier
SOURCE: Canon IR 8500 Error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
Posted on Aug 05, 2008
KyoDoc
  • 38 Answers
SOURCE: Canon copier ir 3100 cn error code E000602 - 0202
the hard drive containing the software that drives the machine has an error. Corrective steps would be to contact to a Canon technician, who can first try to re-install the software, and if this doesn't work the hard drive has probably crashed, meaning that the drive will need to be replaced and the software re-installed
Posted on Jan 23, 2009
redzventures
  • 149 Answers
SOURCE: IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Posted on Jul 06, 2009
SOURCE: Canon NP 6030 Error code E010
chiudere sportello superiore destro
Posted on Oct 16, 2009
  • 4 Answers
SOURCE: What is error code E000001-0004 and E000001-0010
This error code is a sensor in the side where paper jams usually occur open the door and look for a small sensor in black plastic, it will probably be not located properly these are known for dislodeging, Canon engineers simply glue them back in, switch off the power beofre doing this and when you switch back on it should load ok.
Posted on Apr 20, 2010
Canon pixma MP950 error code 8500
I think you need to reinstall printer driver again, Be sure unistall by REVO then reistall the drivers again.
Download the printer drivers from this link Pixma MP950 Driver download
http://printer-driver-download.us/canon-pixma-mp-950-driver-download/
Feb 12, 2013 | Canon PIXMA Office Equipment & Supplies
Ir 85 error code E000015-0000
hello
8500 IR copy machine
E00015 - 0000 errors.
Please guide me.
I also translated by the site you have to translate the sentences. So you have the goodness wording is easy.
Thanks
Nov 19, 2012 | Canon imageRUNNER 8500 Copier
Error E354-0002 ir 8500
Error E354 in Canon iR 2016
error e354 code appear when you replace PCB controller board.
Please note. Before replace your PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
Aug 27, 2011 | Canon imageRUNNER 8500 Copier
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
What is error code E000001-0004 and E000001-0010 for canon copier 8500
there is a good possibility that the main thermistor and the sub thermistor has gone bad or is dirty. also it might need adjusted to be better placed next to the upper fixing roller
May 19, 2010 | Canon imageRUNNER 8500 Copier
Error Code 00510 Canon 8500 What is it?
pls check yr saddle finisher.[ feed motor]
Mar 04, 2010 | Canon imageRUNNER 8500 Copier
Feb 23, 2010 | Canon imageRUNNER 8500 Copier
Canon ir 8500 error code 001-010 and E 001-003
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
Apr 15, 2009 | Canon Office Equipment & Supplies
Error code E000732-0001Imagrunner 8500
that's reader controller board or main controller board, may send back to repair.
Dec 15, 2008 | Canon imageRUNNER 8500 Copier
56 people viewed this question
old marine
old marine
