Question about OKI C5400 Laser Printer
Fatal error message service 902 thermistor - OKI C5400 Laser Printer
4 Suggested Answers
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: Fatal Error
Did you try cleaning the led heads
Posted on Apr 25, 2009
SOURCE: Error message: Service Call 980 - Fatal Error
It means a call to OKI will be necessary. Typically, fatal errors are related to internal ROM, or board components that effect the boot process of the printer. When it can't boot - you get this type of message.
Posted on Dec 31, 2010
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
Dec 31, 2010 | OKI Electric Industry B4545 Laser Printer
Our OKI C5100 is showing 171:Fatal error. What should we do?
The 171 Fatal error:
Upper Thermistor, State:Open
When an open circuit has been detected in the heat roller thermistor (low temperature)
Check the heater connector and the thermistor connector to make sure they are seated properly. If OK you probably need to replace the fuser.
Hope this helps.
Sep 03, 2009 | OKI C5100n Laser Printer
My OKI printer is giving me a message which reads, "Service Call 106: Fatal Error".
YYYY
106: FATAL ERROR
An error has
occurred which
requires service.
YYYY = the general
cause. 106 = error
number.
Try turning off the
printer then turning it
back on. If this does
not remedy the
problem, write down
the message including
the error number
“106,” then call your
authorized Oki Data
Service Dealer for
service.
Note: If you see a
series of octets
containing letters and
numbers scrolling
across the display, be
sure to write these
down also and report
them to the Service
Fuser error. Replace fuser or if no-go, Main board.
Aug 26, 2009 | Office Equipment & Supplies
Service Call 172 Fatal Error
Hi stuart34:
Here is your problem.
Service Call
172: Error
176: Error
High temperature
error detected at
Thermistor.
1) Is the error message displayed?
2) Does the error repeat?
Yes
Yes
Turn off/on the printer.
Replace the Thermistor and turn off the
1 Upper roller 2 Lower roller 1
b
Thermostat Thermostat
Heater Between pins a and b:
Between pins c and d: 231.4kω
Between pins e and f: 231.4kω (at 25°C)
Between pins c and d: 0ω or open
Fuser Unit
a
b
Heater
e
f
Thermistor
c
d
Fuse
e
f
Thermistor
c
d
printer. Leave it for 30 min.
The Thermistors are located in the fuser assembly.
Hope this helps
May 29, 2009 | OKI C9300hdn Led Printer
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
Error number 172
the problem is on the fuser unit, ther thermistor on it is damaged.
Jun 02, 2006 | OKI C9300 Led Printer
OKI C5400 Laser Printer Logo
48 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
