Question about Bissell 1400 Little Green Pro Canister Steam Vacuum
Won't spray water - Bissell 1400 Little Green Pro Canister Steam Vacuum
What might be the reason water won't reach carpet from tank
Hi Martha. No spray could be caused by a number of things. I'm sorry you're experiencing difficulty and I understand how frustrating this must be.
I want to provide you with a terrific FAQ that will give you a complete list of troubleshooting steps to resolve the no spray.
Here's the link: http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jun 26, 2013 | Bissell 8930M Upright Steam Cleaner
Won't dispense water
Hey Parker. I know how frustrating no spray can be when you're ready to clean your carpets.
Here's a complete list of troubleshooting steps to assist you:
Mar 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
Rug doctor won't spray water
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
Oct 17, 2012 | Rug Doctor Mighty Pro X-3 Ready Pack...
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
My steam cleaner is not spaying water on the carpet?
I found that if the water is not hot enough it won't create the suction needed for the water to spray. If you have use it in the past it could be that the water tubing could be clod.
Jul 21, 2011 | Bissell 1770 Quicksteamer II Upright...
I have a Bissell 2x Turbo 9300 shampooer. It won' spray from the carpet/floor position. I re-booted it and checked for blockage - nothing. I flushed the hand attachment and got it to spray some...
The heater is glogged trust me. It is the size of a dollar bill with seven screws. take it apart and clean the water path also take a small drill bit to the ports of the heater.
May 31, 2011 | Vacuums
Bissell 1400 Little Green Pro Canister Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
