Question about Motorola Mobility H700 Wireless Headset
Connection failed My headset paired with my Blackberry as described, but will not connect. No beeps nothing....failed connection alert. I have put it back in pairing mode and started over, but same response.
  • killeralto Dec 19, 2007
    same problem with my new Blackberry Pearl
  • sheree827 Jul 16, 2008
    I have the same problem with my Blackberry 8830. I deleted the device and added it again. Worked for a little while but then stopped. I just get a message stating "initializing" but it never opens voice dial. I can use it fine once I dial the call.
Read the "force connect" solution below... I was having the same problem and it worked for my blackberry. Good Luck!
Posted on Jan 06, 2008
I have a similar problem with my blackberry curve, it connects but when I hit the key on earpiece for voice dial, the blackberry says setting up, or something like that, and it never connects all the way, just keeps trying, i can dial a call through my phone and then i do hear and can be heard with earpiece, just no voice dialing options??
Posted on Dec 20, 2007
SOURCE:
My blackberry bold 990 cannot discover my samsung wep200 bluetooth headset, both are on and working but whether I try and "discover" or "listen" for the bluetooth, the blackberry never finds it. Help.
Is this Blackberry a corporate Blackberry, there may be some corporate policy blocking bluetooth connection. Check with your company IT support.
Are you able to discover and connect to other Bluetooth devices?
To put the WEP200 into pairing mode, the user must ensure the headset is off then press and hold the multi-function button for eight seconds, or until the LED glows a steady blue. Samsung uses the standard "0000" as the pairing code for the device.
Hope this helps
May 18, 2014 | Samsung WEP200 Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
I connected my plantronics voyager pro to my blackberry bold and they connected fine (never asked for passcode) but there is a continual beep in the back round that makes the sound of the other call be...
Try to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
May 02, 2011 | Plantronics Voyager PRO Bluetooth Headset
I cant receive anythin om my bluetooth yet i can send,,,my device cant be paired
Hi,the BlackBerry Pearl is a versatile mobile phone. It's primarily a Smartphone that's suitable for business use but it's also equipped with some decent entertainment features. The pearl can also play music files which you can enjoy with the help of a hands free Bluetooth headset. Let me teach you how to pair a Blackberry Pearl Smartphone to a Bluetooth headset.
Things You'll Need:
* Blackberry Pearl Smartphone
* Bluetooth headset
Turn on your Bluetooth headset by pressing and holding the multifunction button.
Check if the LED light is a solid blue. Turn off the headset and repeat the first step if the light is blinking.
Activate the Bluetooth wireless connection on your BlackBerry Pearl by Going into your "Settings" menu
Select the "Options" menu to go to your connectivity settings
Click on the "Bluetooth" option to activate the connection
Choose the "Add Device" option on your BlackBerry Pearl to locate the headset
Wait for a while as your Smartphone locates the Bluetooth headset
Enter 0000 for the password after selecting the headset to complete the Bluetooth pairing process
After that, your Done !!!!you can now send and receive. But after following this instruction and no solution yet, that means there is something wrong with your blue tooth. Corrupted. You will need to reset the phone.
Mar 11, 2011 | RIM BlackBerry Pearl 8120 Cellular Phone
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
When trying to connect the headset to my Blackberry Curve it wont connect
If you are getting a connection failed message, I would suggest powering off the headset. Then remove the battery from your cellphone while it is powered on, leave it out for 10 seconds, put it back in and reboot the phone. Power the device back up and put it into pair mode if necessary, then re-search in your bluetooth menu and select the device.
Rylan
Dec 15, 2010 | Jabra Bluetooth Headset - BT2070
How do you put in pairing mode?
Here's how to get the LG HBM-710 Bluetooth headset into pairing mode:
While the headset is OFF, press and HOLD the power button. CONTINUE to do so even after it has powered up. About 3-4 seconds after the startup beeps there will be one more beep. Then, the red light will go solid.
You are now in pairing mode! Hooray!
Go through the necessary 'Add a Device' steps on your cell or whatever and you should be G2G!
Mar 24, 2009 | LG HBM-710 Wireless Headset
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my...
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Jan 18, 2009 | Motorola Mobility H700 Wireless Headset
Motorola H700 Problems with BB Pearl 8100
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jun 02, 2007 | Motorola Mobility H700 Wireless Headset
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Apr 19, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
348 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
