Question about Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range
Thermador model RDFS30QB fault code F1
When the oven is turned on it begins to heat but within 5-10 minutes the unit starts beeping and an F1 or an F3 fault code will appear on the panel. According to the Thermador Fault Code listing both codes require a replacement of the ERC - Electronic Range Control. What part is that exactly? Is there a part number? Also, the unit is 16 years old and is a gas range with an electric oven. To add to the problem, the range has 4 burners with the left 2 burners being 'simmer' burners. The simmer burners are currently not working and this is the fourth time that this problem has occurred since I have owned this model. I have replaced the simmer switches the prior 3 times when they have quit working. Since this seems to be a short term fix is there another repair option I should be looking into to get longer operating life with the simmer burners? Is this a common problem with Thermador ranges?
2 Suggested Answers
SOURCE: oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Posted on Oct 19, 2008
My range has an F1 code
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 12, 2010 | Maytag MES5770 Electric Kitchen Range
Display panel on stove not working properly, cannot use the oven
&^%$tr
Jan 11, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a maytag oven with f1 and f3 codes what
F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
F3: Open or shorted sensor. The cancel key resets the control and stops the alarm. If fault is still present it will reactivate the alarm when the cook mode is chosen. Correction: Check sensor and wiring for shorted or open circuit.
Nov 09, 2009 | Kitchen Ranges
F1 Appears on Kenmore Electric Range
Sep 23, 2009 | Kenmore 90154 / 90152 Electric Kitchen...
GE Profile Double Oven F1 Error
&*&^%rt
Aug 08, 2009 | GE Profile JTP56 Electric Double Oven
Oven door locks, the panel beeps, and displays F1 error code
gy^%$^
Jun 08, 2009 | Kenmore 92320 / 92321 / 92322 / 92324...
Stove beeping and error F11
Jan 22, 2009 | Kenmore 47153 Stainless Steel Dual Fuel...
Oven "beeping" wont stop
Sep 12, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
Kenmore builtin oven model 911 4742990
Sep 03, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
Kenmore Oven model 790-30179400 code F11
Jul 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range Logo
37 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
