Question about Locks & Locksmithing
How to removed a Omnia deadbolt? - Locks & Locksmithing
Removing carbine 4011 deadbolt
remove the screws with proper screwdriver then perform the replcment
if u need any details
Oct 04, 2008 | Deadbolt RF Remote , Satin Nickel
I can't figure out how to remove deadbolt since it doesn't have any svrews
I think you may have a friction fit type of deadbolt. Remove the door knob or the knob you turn to slide the deadbolt. There should be a shaft that comes out with the knob and was sticking through the inside part of the deadbolt. Now pull the deadbolt straight out, you probably need pliers for this part, be gentle so you don't take the finish off the bolt. I hope this helps, if it doesn't then I may need more info.
Sep 24, 2015 | Deadbolt Locks & Locksmithing
How do i remove the plugs covering the screws on the schlage deadbolt?
Schlage FAQs Schlage
The double cylinder deadbolts are keyed on both sides. On the interior side of the home there are drive pins (sometimes called screw covers) covering up the screws. Recommended method: Indent the center of each drive pin with a nail punch. Then use a carbon tip drill bit (about the size of a pencil lead) and ONLY go down 1/8". The drive pin will disintegrate. The drive pins will need to be replaced as they are no longer usable.
Sep 16, 2014 | Schlage Deadbolt. Double Cylinder Deadbolt...
How to remove plugs from schlage deadbolt?
Thank you for your inquiry. These are small plastic plugs on your double cylinder deadbolt. These are just held in through friction. Just take a small screwdriver and pop them out. Factorylocks.com can help you with your Schlage hardware needs.
Mar 29, 2013 | Schlage BE365-PLY BE365PLY626 Satin...
Double cylinder deadbolt, bolt stuck in jam
You will have to remove cylinders from both sides of door, then stick a phillips screwdriver thru the bolt and push the screwdriver toward the hinge edge of the door.Might take a bit of pressure, depending on how hard its wedged into the jam, and you might break the bolt, but thats about the only way to get it out.try to determine why it got stuck before installing new one.
Oct 22, 2012 | Schlage Deadbolt. Double Cylinder Deadbolt...
Bolt doesn't open all the way
You should replace your batteries as the motor that moved the deadbolt does not have enough power to move it with weak batteries. If that fails make sure the deadbolt moves freely when the lock is removed as the mis-aligned mounting will cause excessive force be exerted to move the deadbolt. See http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Dec 13, 2010 | Weiser Lock ED1460X3VKD Powerbolt 1000...
I have a schlage deadbolt, keyed on both inside & outside but neither have any screws to remove. How do I remove the deadbolt?
There should be caps over two screws above and to both sides on the interior key cylinder. Carefully use a pointed tool to pry them out. This will expose the phillips head screws that hold the two halves of the lock together.
Sep 24, 2010 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
Deadbolt wont unlock
Remove the deadbolt cover by removing the 2 screws. This will get you inside the deadbolt. Try using a screwdriver to pull it back. You may in the end have to break the unit in order to get it out and replace it. I have the same thing happen with a deadbolt. I ended up having to destroy the unit to get it out. You are going to replace it anyway so do whatever it takes to get it to unlock so you can then remove it from the door and install a new one. You do not want a deadbolt that will not unlock.
Jan 09, 2010 | Kwikset Brz Sgl Cyl Deadbolt
Tubular design deadbolt stuck in lock position. Door cannot open.
if you remove the screw from the deadbolt and remove the keyed parts you can see the plunger assembly. you can use a flat head screw driver and turn the plunger in. it will unlock the door and you will be able to replace the deadbolt
Sep 13, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Locks & Locksmithing Logo
213 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
