Question about Refrigerators
Viking refrigerator beeping with 5hr display - Refrigerators
Viking fridge beeping and showing code 5Hr
5hr is shr
showroom mode is turned on
Aug 17, 2017 | Viking Refrigerators
Viking fridge top and bottom model#vcbb536rss is beeping sporadically, the display screen is flashing, what is wrong with that? what part we need to check?
high low voltage board were likely not needed
board registers high temp and after a few days of constant high temp alarm will restart
by replacing low volt board all you did is start with empty register also when replacing low volt board they have to be programed for your model
sounds like you need service for your cooling issue
May 31, 2017 | Viking Refrigerators
I have a Viking model# DFUR144FR Refrigerator and it is flashing"e3" and beeping
E3 evaporator thermistor fault out of range you would have to access to evaporator coil to get at the thermistor and you would perform a continuity test to assure it was functioning properly. If you have any questions message me back Thanks
Rick
Sep 28, 2011 | Viking DFUR144FR Compact Side by Side...
My viking vcrb 364 all refrigerator beeps 5 times and the lights are scrolling. Manual is unclear about cause.
Check power is proper.And also check neutral is not weak in plug point. Plug with some other point to confirm fridge in under problem. Check with amps meter holding phase or neutral wire for checking compressor is on or taking over current. Due to over current (high amps) light scrolling and beeps sound will be there.. If high current in compressor, call repairman to replace it.
Check what manual you're having is equal with this pdf format.
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m3020004_F20603.pdf
Thanks.
Jan 23, 2011 | Viking Professional VCRB364 Refrigerator
It beeps randomly - the same beep when the door is open for a while
are you getting any display codes or warning lights?? It may just need the cond coil cleaned up top.
Find the switch that the door hits to shut off the lights. push it to see if the lights go out. It could be a bad lite switch
Nov 21, 2009 | Viking VCSB483 Side by Side Refrigerator
Viking Refrigerator stopped cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 12, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Beeping noise
try shutting the power off to the unit, tere is an on/off switch behind the top grill. It will reset the control board.
Jan 18, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Viking VCBB362
Press Display on
then press and hold Max Frz and Display off, you should hear 3 beeps and the compressor should start.
It may also be that when you turned the unit off you hit the showroom switch that is located up behind the top grill, the power off switch is also in here.
The easy way to tell the difference is see which one turns the lights off, the showroom switch will not affect the lights.
With the lights on switch the other switch and leave it for 6 mins to see if the compressor, if not repeat.
Dec 29, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Viking beeping
do you notice alot of ice builup on the freezer back wall? if so you need to defrost it and more than likely replace the defrost terminator. make sure you remove the back panel and use boiling hot water to remove the ice( i normally use a coffee cup) part # 10442407 ONLY USE VIKING PARTS) others may tell you to use whirlpool or some other but DON'T
Mar 29, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
All lights went out in my refrigerator/freezer
I have this side by side Viking- The worst product I ever bought. Nothing but problems. If I can give anyone advise do not buy one.
Feb 11, 2008 | Viking 42 in Built In Professional...
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
