Question about Emerson Smartset Clock Radio
Caller ID Screen not working
I recently unplugged my clock and when I plugged it back in the caller ID screen will not show any writing. It lights up but doesnt show the history or an incoming call. The button the flashes showing a new call is always flashing, but I cant see who the call came from. Help its driving me crazy that I cant use my caller ID.
  • Anonymous Dec 29, 2007
    same deal, lost power and now caller id functions will not work at all, would love a solution.
    President:
  • 814 Answers
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 14, 2009
6ya staff
SOURCE:
Need a caller ID that hooks up to land line phone line and shows on television screen.
Contact your phone service provider to setup caller ID and ask them if they do the TV service as well
the service provider has to enable caller ID before any plug in box will display the number there is a charge for the service depending on the package you have
Dec 11, 2016 | Lands Phones
I recently bought a 82738. Caller ID shows up on the screen as "Unavailable" rather than caller info. I had my former TV, a Mitsu73 inch hooked up the same and caller ID worked fine. Any...
The T.V. caller ID is from your phone provider. The T.V. itself shouldn't have any impact on how the caller ID works. I would call your phone company and see what they say, it sounds like a problem on their end.
May 05, 2011 | Mitsubishi Televison & Video
I just received KX-T7730 phone with an LCD screen and it is not showing the caller ID # that is dialing in. It only displays CO 1. The previous phone similar to KX-T7730 shows the caller id #. So how can I...
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
Hope his help and rate please.
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
AT&T 974 Caller ID has quit.
Unplug everything then replug should reset the Caller ID
Dec 11, 2009 | AT&T ATT-974 Corded Phone
I can only see the are code on caller id display, how do I see the whole number?
Sometimes your telephone basestation need a reboot...
Try unplugging everything on the base station, shut it down for say 20 seconds to let all the power drain from it.
Then plug everything back in (power and phone cord).
After that try calling or get someone to call you and see if the Caller ID vcomes back.
May 01, 2009 | Lands Phones
Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Mar 06, 2008 | Vtech ia5864 Cordless Phone
Caller ID
Is your CallerID server module plugged in?
Jan 25, 2008 | TMC M4810 NON-KSU Corded Telephone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Emerson Smartset Clock Radio Logo
102 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
